It is currently Sun Oct 11, 2026 10:13 pm
 Post subject: 0 bytes in a folder (huh)
PostPosted: Sun Oct 07, 2018 5:06 am  (#1)
Earlier this year I bought a new computer and immediately (I thought) did an Windows image backup of the computer onto my portable hard drive. Took a couple hours to complete so I was confident it was done. Thought I would have a look at how much space it took up as I also want to use the drive for back ups. Anyhow I have found out now that the Image Folder has 0 bytes.
The drive holds almost a terabyte of stuff, so I doubt it was too small.
I do leave the drive plugged in as I have back ups scheduled. Could the image have been erased? Maybe it wasn't done properly at first?
 Post subject: Re: 0 bytes in a folder (huh)
PostPosted: Sun Oct 07, 2018 9:48 am  (#2)
I'm curious what software you used to make the backups.
I've used Windows imaging software in the past,
and have experienced issues with missing, corrupt, incorrect and incomplete images/data backups.
Which is very unreliable for backing up my files.
I use Macrium Reflect for all my backup needs,
and haven't had any issues with this software.
In the 5 or more years I've been using it.
PostPosted: Sun Oct 07, 2018 10:45 am  (#3)
Just used Windows/the computer's program.
If I have a backup of files now do I need an image as well?
Will look at getting another program.
Edit:-
It was a System image and I would have done it before I did much on the computer. Whether it uses a windows program or a HP one I do not know.
Even if I hadn't done anything or transferred stuff over from my old computer it should have saved my System, eg programs?
PostPosted: Sun Oct 07, 2018 11:02 am  (#4)
Having a System Image,
will let you restore your entire system,
at the point were the backup was made.
It's usually best,
to create a System Image.
When you know your system is in a good configuration.
Whereas backing up individual files,
only restores those files and not the OS.
If you're not concerned with the OS taking a nosedive.
Then a system image may not be for you.
However,
you will need a functioning OS.
To be able to recover the files saved to a backup.
Either way,
having a backup for your files/OS and or both.
Is something we all should get accustom to doing.
There are 2 programs,
that I would feel comfortable recommending.
1.) Acronis True Image
2.) Macrium Reflect
I personally us the paid version of Macrium Reflect.
PostPosted: Sun Oct 07, 2018 11:25 am  (#5)
PostPosted: Sun Oct 07, 2018 11:36 am  (#6)
Try un-plugging the HDD and then plug it in again. Win10 gets pretty squirrely sometimes.
I once made a system image for my Son's Win10 Laptop and put the restore image on a second partition I created. Win10 couldn't see it, even though it was there. I then made the image onto an external drive. Started Win10, plugged in the drive, then copied the image onto the second partition.
PostPosted: Sun Oct 07, 2018 11:45 am  (#7)
sallyanne wrote:
