It is currently Fri Oct 16, 2026 4:28 am
 Post subject: Taskbar Problems
PostPosted: Wed Mar 13, 2019 6:45 pm  (#1)
My laptop went through a series of updates last night and now today, the e-mail icon my taskbar looks like this:
I don't use the e-mail and I have checked every box within the e-mail app to see if there was e-mail unanswerd... nothing. I recall using a batfile to correct a similar problem I had before. I now can't find the file. Any help would be good.
 Post subject: Re: Taskbar Problems
PostPosted: Wed Mar 13, 2019 10:13 pm  (#2)
The simplest way,
would be to right click on the icon and unpin it from the taskbar.
This should remove it.
You can also check at this location on your C drive:
%AppData%\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar
Look for the mail icon and delete it.
PostPosted: Thu Mar 14, 2019 1:23 pm  (#3)
Also do a quick settings check; PC Settings, Apps, Default Apps to make sure that Mail is not showing as your default email....
I've had that change on me after an update....
PostPosted: Thu Mar 14, 2019 10:58 pm  (#4)
I managed to fix it with Wallace's help.
