It is currently Sun Oct 04, 2026 9:12 am
 Post subject: A question to Wallace (or any other expert in win 10 sys)
PostPosted: Thu Feb 27, 2020 2:06 pm  (#1)
Wallace,
if you will, could you please have a look at post #16 on the thread related to my new published filter Aquarelle Plus?
Level-0 encountered an error that to my system ignorance appears to be a system error and not an application error.
Do you have any experience on such kind of errors?
Could you suggest how to avoid it?
Thanks a lot in advance.
 Post subject: Re: A question to Wallace (or any other expert in win 10 sys)
PostPosted: Thu Feb 27, 2020 5:23 pm  (#2)
In anticipation of an expert, a few thoughts:
I used to have a similar problem - I couldn't use Gimp and Firefox at the same time (one caused the other to freeze) - but after one update the problem solved itself.
Unfortunately, I don't know which program was the reason: Gimp, Firefox or Windows.
Everything points to Windows and a similar problem (because of gspawn-win32-helper.exe) was reported here:
https://gitlab.gnome.org/GNOME/gimp/issues/4582
(pay attention to: or maybe some non-plug-in files, in any plug-ins folder?)
DIEGO_ARTISTIC_AquarellePlus.py works fine for me for Win10 64bit and Gimp Samj 2.10.14 - 2.10.18.
PostPosted: Thu Feb 27, 2020 6:15 pm  (#3)
Expert?
:rofl
It looks like a gspawn-win32-helper.exe error.
From what I understand about the,
gspawn-win32-helper.exe.
It's an executable file that was part of the GIMP 2.6.11.
locate it and move it to a different location.
This might stop the error.
If not move it back.
PostPosted: Thu Feb 27, 2020 10:42 pm  (#4)
Many thanks Wallace and Marero.
I pointed here in a message to level_0.
PostPosted: Fri Feb 28, 2020 3:16 am  (#5)
:wvy
thank you MareroQ,Wallace,dinasset
I just searched for "gspawn-win32-helper.exe" with Everything software:
I'm watching this this afternoon. :)
PostPosted: Sat Feb 29, 2020 3:07 am  (#6)
:wvy
In D: \ Gimp-2.10.14_Portable-32-64bit-Win \ bin, I have:
so I move the 2 or only the gspawn-win64-helper.exe?
PostPosted: Sat Feb 29, 2020 11:29 am  (#7)
level_0 wrote:
:wvy
The name of the file which had given the error is gspawn-win32-helper.exe
Move this file temporarily form it's location.
To test if this fixes the error.
