It is currently Tue Nov 17, 2026 5:11 am
 Post subject: Pango Markup for GEGL
PostPosted: Sat Oct 29, 2022 1:31 pm  (#1)
learning. :bigthup
 Post subject: Re: Pango Markup for GEGL
PostPosted: Sat Oct 29, 2022 8:21 pm  (#2)
If you use it in the graph it will be able to chain other filters like my text stylers. This project will likely take about a year to finish if it does.
PostPosted: Sat Oct 29, 2022 9:06 pm  (#3)
Thx! I'll have to give that a try. :bigthup
PostPosted: Tue Nov 01, 2022 6:50 pm  (#4)
What does this plug in do and is it available for Windows users?
PostPosted: Wed Nov 02, 2022 12:37 am  (#5)
I did compile it for Windows 64 bit to test for contrast. It is a GEGL filter that allows you to type Pango markup language into a text box and see the results. Sort of like typing HTML, or CSS Style sheets but it is different.
