It is currently Tue Nov 17, 2026 12:12 am
 Post subject: Re: What filters/scripts/plug-ins do you use the most?
PostPosted: Wed Mar 01, 2023 10:55 am  (#1)
Stroke off one filter, because in Gimp 2.10 the JPEG export has a "how preview in image window" options that shows you how bad the image becomes and how big the file is in real time, and therefore replaces most of the "Save for web" plugin.
Otherwise there are few of my filters that I use very regularly: preset-guides, path-to-shape, path-edit, layer-tiles, perspective-stack, imgur-upload off the top of my head.
PostPosted: Wed Mar 01, 2023 9:15 pm  (#2)
What I use the most depends on what type of project I'm working on. Right not I'm doing family photo restoration, color and lightness/darkness adjustments, some scratch and defect removal, depends on the photo for what plugin works better, i'm learning much, and sometime forgetting just as quickly. :|curves, gmic, several others.. need more time in the day to play with them. ;)
PostPosted: Thu Mar 02, 2023 12:52 am  (#3)
I use a simple script I wrote long ago called 'Export to directory' the most for saving images or files for posting to the web and keeping for future reference.
Remember to alter name and paths at top of script
Others are still probably using this simple and easily modified script
PostPosted: Thu Mar 02, 2023 1:17 am  (#4)
Plugin would be GMIC, still finding new things in there
I use the enhancement tools alot
The colour menu tools
Filters - I use Nik's define 2 rather than any gimp denoising or GMIC ones.
I rarely use any scripts and other plugins now
PostPosted: Thu Mar 02, 2023 9:27 pm  (#5)
Export to Directory was made in a rush for 2.6 and probably needs a rewrite by now
PostPosted: Thu Mar 02, 2023 10:11 pm  (#6)
Because in all my old works and particularly glass works from 2014 onward, I used Bevel Reflect Logo from Gnu Tux, it was and still is my favourite and the one I use most. Nowadays I use it to work wonders with mandalas..
Next comes Ofnuts 'Generate Intermediate Paths', then 'Lines Between paths' from Trandoductin.
PostPosted: Fri Mar 03, 2023 1:18 pm  (#7)
As requested here is a copy of Tim's Lines Between Paths plug-in.
Lines_Between_Paths.zip [1.39 KiB]
Downloaded 99 times
PostPosted: Sat Mar 04, 2023 2:05 am  (#8)
My favourite filter for denoising and smoothing before I found Niks denoise was 'thin brush' but it often smooths the photos in a way that distorts them. Many of the denoise and smooth filters are made for large photos, not smaller ones
