It is currently Fri Oct 09, 2026 10:08 am
 Post subject: Abstract Art by Discovery out of Geometric/Basic Shapes
PostPosted: Sun Jul 16, 2023 5:01 pm  (#1)
The idea is from an old fractal program I used to use where you're shown a grid of 9 squares of variations and you pick one to see it evolve from there and then you're another 9 and so on down the evolution path this cuts down the number of choices you have to make out of a huge possible number of combinations.
I copied-cat or copycat-ed the same method and applied it to this simple program
You simply choose an element out of Solid Rectangle, Hollow Rectangle, Solid Circle, Hollow Circle, Solid Triangle, Hollow Triangle, or a Line.
Then it shows you 16 variations all in black color.
You choose one or if you'd like to see you just click Generate again and again after you click on one, it now draws your chosen one in 16 random colors. You choose a color or keep clicking generate until you see a color you like and click that one.
At this step if you haven't chosen multiple generates you already chose 1 out of 256 (16^2) combinations.
If you repeat this for even just 6 shape/color combinations you already have something that you likely liked most out of 2.8147498e+14
Which is a huge number of combinations.
When you're happy just zoom out to see large canvas drawn on bottom to right click and save as image or copy image.
That's it.
Here's the video demo https://www.youtube.com/watch?v=kWMRvH5pfkc
And here's link to js program: https://tinmantaken.blogspot.com/2023/0 ... overy.html
Here are a few pieces I chose
 Post subject: Re: Abstract Art by Discovery out of Geometric/Basic Shapes
PostPosted: Sun Jul 16, 2023 6:16 pm  (#2)
And then I bumped map using a generated texture and displaced map, rotated 90 displaced map again then rotated it back and have this
PostPosted: Sun Jul 16, 2023 9:53 pm  (#3)
I plan to alter this program to allow user to choose from elements which are abstract paint splatters (or instead of choosing it just random picks one) or both. This would be much cooler I think than geometric shapes.
PostPosted: Mon Jul 17, 2023 2:06 am  (#4)
Online
Looks promising Tim!
PostPosted: Mon Jul 17, 2023 6:46 am  (#5)
:) Skinnyhouse.
PostPosted: Mon Jul 17, 2023 7:18 am  (#6)
Move over Modrigan. Cool stuff, Tran. :)
PostPosted: Mon Jul 17, 2023 8:13 am  (#7)
What's Modrigan?
PostPosted: Mon Jul 17, 2023 10:36 am  (#8)
trandoductin wrote:
What's Modrigan?
I think Lylejk means Piet Mondriaan, the Dutch painter.
Piet Mondriaan
PostPosted: Tue Jul 18, 2023 8:39 am  (#9)
Thanks Ella I kinda thought that but wasn't 100% sure.
PostPosted: Wed Jul 19, 2023 5:30 am  (#10)
Speaking about Mondrian...
https://www.theguardian.com/artanddesig ... r-75-years
:rofl :rofl :rofl
Patrice
PostPosted: Fri Jul 21, 2023 10:11 am  (#11)
hhahah upside down, that's great.
