It is currently Wed Nov 18, 2026 3:00 pm
 Post subject: Hand-draw your own border/frame
PostPosted: Wed Sep 13, 2023 11:09 pm  (#1)
I have built a plug-in before that takes a tile and make it into a frame by mirroring and rotating.
But it wasn't interactive because you did a tile and then you won't see end result until after plug-in is ran.
So I have decided to redo this in Javascript so that it's more interactive. It's basic mouse drawing that lets you change color and brush-width. But it can be beautiful and fun.
You can configure the Tile to draw larger for more details and configure the frame with different options.
Here's the link to the tool: https://tinmantaken.blogspot.com/2023/09/hand-draw-frameborder-freehand.html
And here's a sample screenshot of one I did for fun.
 Post subject: Re: Hand-draw your own border/frame
PostPosted: Thu Sep 14, 2023 8:10 am  (#2)
hehe
PostPosted: Thu Sep 14, 2023 9:22 am  (#3)
Used tool to create this frame.
Then in GIMP changed color and made a duplicate of frame made it darker color and offset it a little to create depth/thickness.
PostPosted: Thu Sep 14, 2023 2:21 pm  (#4)
Does some interesting things when you try to go over it with another colour.
PostPosted: Thu Sep 14, 2023 2:51 pm  (#5)
What? How are you getting that? I just get color not XOR mode like that.
PostPosted: Thu Sep 14, 2023 3:10 pm  (#6)
I painted white over black then continued painting white spots. I think the second time you paint over it uncovers the original instead of covering it. I didn't understand it myself!
PostPosted: Thu Sep 14, 2023 3:18 pm  (#7)
No, I'm really not sure what it is doing.
PostPosted: Thu Sep 14, 2023 3:26 pm  (#8)
Not sure how to recreate what you're experiencing.
I thought it was transparent colors but yours looks like it's a mixture of drawing modes.
PostPosted: Thu Sep 14, 2023 3:28 pm  (#9)
I wonder. What browser are you using? I use Chrome.
PostPosted: Thu Sep 14, 2023 3:34 pm  (#10)
I am using Firefox.
PostPosted: Thu Sep 14, 2023 4:44 pm  (#11)
Thank you for trying and finding that bug.
It is now fixed (I downloaded firefox and was able to reproduce the bug and fixed it). :D
PostPosted: Fri Sep 15, 2023 5:01 am  (#12)
Nice one! :hi5
PostPosted: Fri Sep 15, 2023 5:10 am  (#13)
All's working fine now.
PostPosted: Fri Sep 15, 2023 5:41 am  (#14)
wow now that's fancy border
PostPosted: Fri Sep 15, 2023 5:49 am  (#15)
It's a shame we can't upload more precise images that we have created in Gimp and have it display those as a border. Still, it's a whole lot of fun!
PostPosted: Fri Sep 15, 2023 6:42 am  (#16)
Say no more :D.
It's now a feature. use GREEN area to choose a file from computer then click Load Selected File.
Like this example (I used your avatar hehe):
PostPosted: Fri Sep 15, 2023 6:56 am  (#17)
WOW! You're a gem Trando :hi5 :yes :jumpclap :clap :paint
PostPosted: Fri Sep 15, 2023 7:21 am  (#18)
All thanks to you.
PostPosted: Fri Sep 15, 2023 11:43 am  (#19)
Updated: You can now choose to load a picture that you want to frame in the tool as well.
Sample.
PostPosted: Fri Sep 15, 2023 12:22 pm  (#20)
Another update:
When you right click on BorderTile I don't draw the custom_Cursor so that the Border Tile is clean for you to Save/Copy-As Image for possible reuse of Border Tiles.
