It is currently Tue Nov 17, 2026 12:42 am
 Post subject: Rembg install issue
PostPosted: Wed Jan 10, 2024 2:45 am  (#1)
Hi, trying to use rembg in GIMP Flatpak in Ubuntu 22.04. When I tried adding rembg CPU - Library + CLI
I got
ImportError: Pandas requires version '3.1.2' or newer of 'jinja2' (version '3.0.3' currently installed).
Started a bug report. Would be nice if someone can help. Thanks.
https://github.com/danielgatis/rembg/issues/563
 Post subject: Re: Rembg install issue
PostPosted: Thu Jan 11, 2024 5:46 am  (#2)
Perhaps it's a flatpak issue? It works just fine in the PPO and appimage versions of gimp here. I don't use flatpak for anything, so can't help. You can always just use rembg via commandline.
PostPosted: Sun Jan 14, 2024 12:13 am  (#3)
Thanks
