It is currently Mon Nov 16, 2026 11:13 pm
 Post subject: Remaking Photoshop Actions in GIMP
PostPosted: Fri Feb 23, 2024 7:38 am  (#1)
a possible client (long gone by now)
directed me to https://www.deviantart.com/rawimage/art ... -853811976
to get an .ATN file. but I tried opening it in sublime and it's all in Hex.
I was wondering if anyone has access to Photoshop to convert the .ATN file to xml or text or any readable format so I can read the actions.
I tried looking at the free trial for Photoshop but the price is too steep for me and I don't want to sign up and having cancel when I don't intend to actually own Photoshop.
I was wondering if anyone knows a way (or has access to Photoshop already) and convert the ATN file to readable actions so I can try to reproduce in GIMP.
In return, I'll share the reproduced result plug-in if successful.
 Post subject: Re: Remaking Photoshop Actions in GIMP
PostPosted: Fri Feb 23, 2024 7:47 am  (#2)
Hello Tin
I can't help with PS, my only suggestion is that you could maybe try Photopea - https://www.photopea.com/
Perhaps this editor could meet your needs.
Good luck.
PostPosted: Fri Feb 23, 2024 8:07 am  (#3)
Thanks Krikor.
I was able to open the ATN in Photopea and see the actions.
but it's a huge list and no properties can be seen which I would need to emulate in GIMP.
PostPosted: Fri Feb 23, 2024 11:19 am  (#4)
I can do this on the latest version of Photoshop I have. CS5 from 2010. It has actions
btw, so does photoshop from 1996.
PostPosted: Fri Feb 23, 2024 11:21 am  (#5)
Send me the atn file and I'll try to make GEGL syntax that mimics it and give you its instructions.
PostPosted: Fri Feb 23, 2024 8:33 pm  (#6)
Hi Contrast,
the ATN, It's downloadable from the link given in 1st post
PostPosted: Fri Feb 23, 2024 8:51 pm  (#7)
I can't download it because I don't have a deviant art account.
PostPosted: Fri Feb 23, 2024 10:30 pm  (#8)
oh right forgot about that here it is.
polagen_4_by_rawimage_de4c5jc.zip [5 MiB]
Downloaded 88 times
PostPosted: Fri Feb 23, 2024 11:08 pm  (#9)
I ran it on 2010 photoshop and it kept warning about missing a few features but loaded this. I do not have access to any later version of PS.
GEGL could mimick this with mean curvature blur, a color tint with color-overlay on a blend mode and gaussian blur, and linear motion blur at very low settings
Here is the output
Would you like me to make a GEGL Graph of this vintage effect?
PostPosted: Sat Feb 24, 2024 5:17 am  (#10)
No I was just wanting to do it as a plug-in for the client.
I don't personally have use for it.
