It is currently Sat Oct 10, 2026 8:30 pm
 Post subject: AVI
PostPosted: Thu Jul 21, 2011 6:19 pm  (#1)
GIMP Version: 2.7.3
Operating System: Windows
OS Version: XP - SP3
GIMP Experience: Basic Level
What kind of video converter software do i use to convert videos to avi ? i searched online and a whole slew of them came up.
 Post subject: Re: AVI
PostPosted: Thu Jul 21, 2011 6:23 pm  (#2)
maybe you should try "Any video converter"
My Flickr
PostPosted: Thu Jul 21, 2011 6:27 pm  (#3)
ok I'll do that, thanks Ana.
PostPosted: Thu Jul 21, 2011 6:28 pm  (#4)
I have several softwares to do this job and also a very good tutorial. If you would like to pm me I can probably help
This is the one I use
http://filepig.org/download/dvd-decrypter/
PostPosted: Thu Jul 21, 2011 6:31 pm  (#5)
do I need to send you anything?
PostPosted: Thu Jul 21, 2011 6:33 pm  (#6)
I'm glad if i helped Alonte :)
My Flickr
PostPosted: Thu Jul 21, 2011 6:37 pm  (#7)
No Almonte, Is it a DVD you want to rip and convert into an avi?
I will try to get the tutorial to you but it has images so don't know if I can. Do you have Word.
You will also have to download DVD DeCrypter....
PostPosted: Thu Jul 21, 2011 6:39 pm  (#8)
No Almote, Is it a DVD you want to rip and convert into an avi?
it's a youtube video
PostPosted: Thu Jul 21, 2011 6:48 pm  (#9)
Xmedia Recode is good but when i grab youtube vids I always use Youtube HD transfer, you can download into different formats, grab them by the batch and just paste the URL with a button. I've found it very handy.
PostPosted: Thu Jul 21, 2011 6:56 pm  (#10)
O, I thought it was a DVD you wanted to convert. I have never tried it with a U-tube vid so maybe Gms9810's way will work.
PostPosted: Thu Jul 21, 2011 8:14 pm  (#11)
If you have Firefox, you should grab the addon: Video Download Helper. Video Download helper will download the video and convert it to an AVI (or other formats) in one step.
You'll need to download ffmpeg (or mencoder) which does the actual conversion. Select the conversion method under Video Download helper's preferences menu/convert. After that, you can just click "download & convert" on any youtube video.
PostPosted: Fri Jul 22, 2011 11:30 am  (#12)
I sometimes use Video Download helper, but as a matter of taking a stand i usually don't because their main is providing porn links. yes, you have to theoretically click the 'adult materia' box but i've had it send me to places in the past that I didn't want to go and i didn't tell them too. But it IS good not only for Youtube but videojug monkeysee etc. Flashgot does the same thing too without the porn suggestions.
PostPosted: Fri Jul 22, 2011 11:34 am  (#13)
I've never noticed anything porn related when using this addon so the porn stuff must not be too obvious.
PostPosted: Fri Jul 22, 2011 4:28 pm  (#14)
it's not really obvious, which is good. if you click on the little rotating red blue and yellow ball things it will open a menu of sites hat it works with. At the bottom there is a check box to display adult content (not quite worded that way) which, if clicked, will pt a bunch of sites in red on the list. My wife and I decided to follow that out, so if you click one of those sites in red, it takes you directly to the downloa helper site (which malware bytes will block every time). You click the enter button there to enter the adult sites. That tells me they have an interest in those sites. The fact that malwarebytes trips out over it every single time is also a bad sign to me. It seems like everything with the word 'helper' in it is in some way nefarious.
I still have it on one of my computers because it's the only extension that will work on some sites (No, not porn sites.)
