It is currently Mon Nov 16, 2026 6:52 pm
 Post subject: Replay Doodle - New feature replay doodle dances to mp3 music clip
PostPosted: Tue Jul 14, 2026 5:16 pm  (#1)
I doodled an red apple for fun
https://purkara.com/replay-doodle/view. ... 553d6c49ee
You can see the full process at different playing speeds.
And you can doodle your own and add the gallery.
It doesn't save it as image but points and brush settings that were used so doesn't take as much space to save and being able to watch yours and others doodle is FUN.
Back when I was making this youtube video, I got a local js/html file that would let me doodle and it would replay it and I found that enjoyable.
So then I wanted to share that enjoyment.
 Post subject: Re: Replay Doodle
PostPosted: Tue Jul 14, 2026 7:30 pm  (#2)
You can now hear sound reacts to brush's attributes during Replay!
Just click "Enable Sound"
PostPosted: Thu Jul 16, 2026 9:39 am  (#3)
People can now reply do doodles with a doodle of their own.
PostPosted: Thu Jul 16, 2026 10:05 am  (#4)
Looks great, Tran; astronomically better than a filter guy like can come up with. lol
Have near 0% patience so watch at 10X speed (could have chosen 20X, but then I might have missed some nuance; lol). :)
PostPosted: Thu Jul 16, 2026 3:33 pm  (#5)
Thanks it's so trippy with sound.
Started sharing these on YT, since the allows for quick MP4 download
PostPosted: Thu Jul 16, 2026 10:39 pm  (#6)
How the heck were you able to add sound effects to your drawing, Tran (that matches your strokes that is)? Trippy for sure. lol
PostPosted: Fri Jul 17, 2026 5:03 pm  (#7)
Well it was silent and then I thought what if it played high notes up higher and lower notes lower down on canvas.
And panning left to right depending on where the brush is on canvas.
I asked ChatGPT what I wanted and it did it all for me since it saves the stroke points and not the drawing itself all the info is there for it to work with.
But, BUT even better now is I had the idea of have random strokes dance to a music sound track and time it so that the doodle plays exact time as the length of the sound clip. and boom chatgpt built that too.
example:
 Post subject: Re: Replay Doodle - New feature replay doodle dances to mp3 music clip
PostPosted: Fri Jul 17, 2026 10:42 pm  (#8)
PostPosted: Fri Jul 17, 2026 11:11 pm  (#9)
example:
Now you're just showing off, Tran. lol
Fantastic stuff. :)
PostPosted: Fri Jul 17, 2026 11:17 pm  (#10)
Showing off what ChatGPT built yeah! a lot of chatting back and forth it's like having my own developer that also shoot ideas back and forth.
PostPosted: Sat Jul 18, 2026 12:21 am  (#11)
:lol coolies
PostPosted: Sat Jul 18, 2026 9:08 am  (#12)
Thanks Sallyanne,
I added explosion of the doodle strokes at the end now, it's optional
PostPosted: Sat Jul 18, 2026 4:17 pm  (#13)
Added 14 most recently used colors, saves and loads next page load as well.
Added 14 most recently used brush sizes, saves and loads next page load as well. This is for quickly selecting between use brush size and colors while doing (more complex) doodles.
