It is currently Tue Nov 17, 2026 11:37 pm
 Post subject: A real nice FREE texture pack
PostPosted: Wed Sep 15, 2010 10:32 am  (#1)
Running around looking for more information on Filter Forge, i ran across this texture pack.Be forewarned it's a huge dl. (250 mb ), but i thought some of you may be interested.Download the texture pack here.
http://torley.s3.amazonaws.com/Torley-Textures.zip
Or you can view each texture separately and dl them that way.
http://www.flickr.com/photos/torley/col ... 588432564/
All Torley Textures are 512x512 in (lossless) PNG format and seamlessly tiling. Use 'em almost however you want — just don't resell as-is.
 Post subject: Re: A real nice FREE texture pack
PostPosted: Wed Sep 15, 2010 10:40 am  (#2)
Nice find. I don't use pre-made textures very often, but these are pretty good.
PostPosted: Wed Sep 15, 2010 11:12 am  (#3)
Wow. I like textures and that is a great pack. Thanks, Rod. :paint
PostPosted: Wed Sep 15, 2010 11:53 am  (#4)
i was just thinking about texture i did so many that i never upload, fearing the were too big...but i see this have a similar size
i just finish to check if are all seamsless...all tiles well here 3 random sample
PostPosted: Wed Sep 15, 2010 11:59 am  (#5)
they are very nice PC.... just grabbed them thanx. :mrgreen:
PostPosted: Wed Sep 15, 2010 11:59 am  (#6)
Happy you like...2 more..feel free to use
PostPosted: Wed Sep 15, 2010 7:58 pm  (#7)
Thanks PhotoComix. Those are wonderful!
Here's one I did. It's seamless.
Used sphere in mathmap with the texture.
PostPosted: Wed Sep 15, 2010 9:27 pm  (#8)
:clap :clap :clap
Cool texture and the sphere is beautiful...
but you remind the sphere of mathmap so i could not resist to see how my texture work...
well...(the white inside the sphere is transparency )
here with a texture from same material (well the blue sphere..) used as the bg
PostPosted: Thu Sep 16, 2010 12:43 am  (#9)
:hi5 :paint2 Beautiful PhotoComix. That sphere from the background looks like jewels from Fabergé. :flirt
PostPosted: Thu Sep 16, 2010 5:23 am  (#10)
Do you like something more "heavy Metal" style?
i got those patterns from another series
Are big ,( but may be scaled down a lot)...and seamless ...no transparencies this time
PostPosted: Thu Sep 16, 2010 8:40 am  (#11)
You do beautiful work PC..... "O" love the colors in yours too.... think I will grab :oops:
PostPosted: Thu Sep 16, 2010 9:47 am  (#12)
How did you get your background to come out transparent, PhotoComix? I used the ellipse tool to get rid of the bg.
I tried a sphere with one of yours. It looks a little blurry in the center.
PostPosted: Thu Sep 16, 2010 10:44 am  (#13)
I grabbed it, it should be fun, thanks.
PostPosted: Thu Sep 16, 2010 11:35 am  (#14)
These are some gorgeous images! Very, very nicely done!
My Sigs = My Photos
PostPosted: Thu Sep 16, 2010 2:20 pm  (#15)
About MathMap for best quality remember to check in "Setting" the supersampling box
about the BG
chose the Sphere filter,(that in Map menu, there is another in Distort ),
click preview
then the "User Values" tab
there in the bottom there is "background "if you click on the color bar will pop out a gimp color widget ....
pull the last slider "A" to the max
I like your sphere...we had a sort of sincronicity, few how ago i used a similar texture to use to confront the Gmic and Mathmap "sphere" filters
Quite stunning result all completly different
here the image i used
here MathMap "rectangle2 ellipsoid" that is used on square image create a sphere
here Mathmap /map /Sphere
PostPosted: Thu Sep 16, 2010 2:55 pm  (#16)
Ah! Thanks for the transparency info. Here's a pattern I made then made the sphere and came out with a transparent bg.
PostPosted: Thu Sep 16, 2010 3:11 pm  (#17)
This was another interesting experiment. I started with a 500x500px image filled with black. Decomposed it. Ran solid noise on each layer of the decomposed image. Then ran the sphere filter on each layer and each layer had transparency around the sphere. When I composed the image, the colored background magically appeared.
PostPosted: Thu Sep 16, 2010 5:08 pm  (#18)
wow a sphere full of poesy so delicate
PostPosted: Thu Sep 16, 2010 7:11 pm  (#19)
the other spheres from same pattern i used different MM filters to get the sphere and they wrap in a quite different way
PostPosted: Thu Sep 16, 2010 11:21 pm  (#20)
Hey 'O',
I tried doing the same thing, and I too got the colorful background! I don't know why, but it came out sweet!
My Sigs = My Photos
