It is currently Sun Oct 18, 2026 3:54 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3  Next
 Post subject: So here i am using Fedora 17 :)
PostPosted: Sat Aug 04, 2012 11:47 pm  (#1)
This is a really nice distro. :)
How do i get Gimp on it?
 Post subject: Re: So here i am using Fedora 17 :)
PostPosted: Sun Aug 05, 2012 12:05 am  (#2)
yum install gimp <---- never mind i figured it out. :)
PostPosted: Sun Aug 05, 2012 1:06 am  (#3)
Welcome to the "other side" of two major Linux camps. :hehe
Grab gnome-tweak-tool. I think you'll find that handy.
This is an excellent guide to help you complete your Fedora installation..
http://www.mjmwired.net/resources/mjm-fedora-f17.html
Out of habit, I don't sudo so I just ignore that bit. You might like to use it tho.
PostPosted: Sun Aug 05, 2012 1:45 am  (#4)
Thanks for the info Tux.
I have another question.I couldn't figure out how to shut-down the computer from the Fedora screen, so i used "Suspend" instead. Well that put my computer into a state of instant hibernation and i couldn't get the suspend off. :lol
So i unplugged the computer and plugged it back in and that took it out of hibernation mode.
But, now i can not set my monitor resolution to 1440x900 as it isn't recognizing my Acer monitor anymore.
My question is how on Earth do you get the computer out of "Suspend" mode once you choose this option in Fedora?
I tried every key on the keyboard, but alas nothing worked. :)
Also how do you shut down through Fedora?
PostPosted: Sun Aug 05, 2012 4:25 am  (#5)
Rod, up in the right hand corner where you see your name. click that, then click log out.
BTW, Welcome to Fedora-17 :pengy
PostPosted: Sun Aug 05, 2012 11:38 am  (#6)
I don't know anything about suspend mode in F17 Rod but in a normal suspend to ram operation, the suspend option changes to a resume option. A reboot would restore everything back to normal and shouldn't affect your supported video modes.
You can bring up the power off/restart menu by hitting ctrl-alt-del on the desktop or as Molly mentioned, from the login screen. I normally use a Cairo Dock addon that brings up a restart/power off menu.
It seems if you could boot to 1440x900 once, you could do it again, unless something changed in relation to the video drivers. 1440 x 900 is the resolution I use. You can check "displays" under system settings to see which modes are available. If everything is working properly, the display will pass a list of the supported video modes to the video driver, which are then displayed under system settings/display.
What model of video card do you use? (lspci from terminal will list it)
PostPosted: Sun Aug 05, 2012 11:41 am  (#7)
Oh yeah, very good! :yes
Welcome to the GNU/Linux world Rod (from Kubuntu user) :jumpclap :pengy
Now you have to suffer and learn for a while :sleepkbd
PostPosted: Sun Aug 05, 2012 12:41 pm  (#8)
True YAFU, :peng
Hey Rod,
I know one app you will be sure to get and that is the one Tux mentioned, Cario Dock, it is so great. Your log in-out also comes with that and you can add all your toys besides what I see on some of your screen shots, lol :pengy
PostPosted: Sun Aug 05, 2012 7:44 pm  (#9)
lol, Cairo dock looks just like the Mac dock.
PostPosted: Mon Aug 06, 2012 3:30 am  (#10)
Looks like i will have to update my video driver. As the display dialog only shows 800x600 and 1280x768 possible resolution settings.
Thanks for all your help guys. :)
PostPosted: Tue Aug 07, 2012 9:08 pm  (#11)
Are you using gnome shell?
PostPosted: Fri Aug 17, 2012 3:44 pm  (#12)
I had to bite the bullet and install Fedora completely as my windows partition decided to kill the windows/system folder :lol
Well now i will be asking a lot of questions :)
What really sucks is i lost all my stuff. :\ <-- sad face
Here we go!
PostPosted: Fri Aug 17, 2012 4:44 pm  (#13)
Welcome to the world of Fedora Rod. You won't have a sad face for long. :teeth
PostPosted: Fri Aug 17, 2012 4:55 pm  (#14)
I forgot to mention that you can hover the mouse over the suspend button and hit the "alt" key to toggle to the Power Off option.
Welcome to the intuitive Gnome3 interface. :roll: :lol
Fire away on the questions. :pengy
PostPosted: Fri Aug 17, 2012 5:10 pm  (#15)
Thanks for the welcome!
When i have a few questions i will fire them at you all.
Currently i am installing WINE so i can use my software i purchased for Windows.
I have Gimp-2.8 and Inkscape already installed. (add remove programs is awesome)
I installed Fedora 17 and all the updates on my F drive.
I didn't mount the C drive so maybe i can still compile for windows users. :)
Now i need Notepad ++ for script writing, and i think im all set for now.
I am loving the OS so far though.
PostPosted: Fri Aug 17, 2012 5:24 pm  (#16)
In Fedora I use Gedit which is a notepad, works great. I think it is one of the defaults but if not just type yum install gedit. in root
In the place of Word I use Libre Office write and I use Libre office impress which you will find in add and remove or I use Yum imstall.
PostPosted: Fri Aug 17, 2012 5:40 pm  (#17)
So far i have only needed to use add remove and the software asks for my root password.
How do i do this in root? (via the terminal)
PostPosted: Fri Aug 17, 2012 5:43 pm  (#18)
I believe it's su - (including the space and hyphen) then press enter. You will then be asked for root's password. Type it in then enter. Then yum install software name. Type exit to exit root then exit again to exit terminal.
PostPosted: Fri Aug 17, 2012 5:46 pm  (#19)
open your terminal, type su - that is su space -
you are now in root.
now type yum install gedit or whatever you want to install
I forgot to mention after you type su - it will ask for your root password, not your log in one.
After your install is finished, type exit enter then exit enter to get out of terminal.
PostPosted: Fri Aug 17, 2012 6:27 pm  (#20)
I have no idea about programming. But in GNU/Linux many people use KDE "Kate" text editor. The problem is that if you're not using KDE, it will install all necessary KDE libraries when installing Kate. Except for that, you can install Kate.
