It is currently Sun Oct 18, 2026 11:56 pm
 Post subject: Opening jar files in Fedora
PostPosted: Tue Aug 21, 2012 3:08 pm  (#1)
Is there a App in the repository or yum install that will do this?
I have a few Java jar files i would like to open.
The files do not seem to open with Java.Or maybe i need an updated Java version?
Thanks.
 Post subject: Re: Opening jar files in Fedora
PostPosted: Tue Aug 21, 2012 3:50 pm  (#2)
same as windoze
open a terminal
navigate to the directory where the jar file is
use the command
java -jar filename.jar
if that is not working, then a straight
java
or
java -version
in a terminal will give info
PostPosted: Tue Aug 21, 2012 3:59 pm  (#3)
Rod, you have two options to run Java in Fedora. You can install OpenJDK (& icedtea) which is probably fine for most uses or you can install Oracle Java.
http://www.mjmwired.net/resources/mjm-f ... .html#java
I tend to avoid Java because of the high security risk with the package. Their track record on keeping security holes plugged isn't exactly what I'd consider stellar.
PostPosted: Tue Aug 21, 2012 4:03 pm  (#4)
Thanks guys. :)
PostPosted: Tue Aug 21, 2012 4:11 pm  (#5)
A bit more
Assuming you have java installed, cant see why not
In win you might have a <something>.exe launcher
the linux equivalent might be a bash script <something>.sh
the contents might look along the lines of (example for imagej
#!bin/bash
java -Xmx512m -jar /home/user_name/ImageJ/ij.jar
and this will allocate extra memory etc.
a couple of ways you can run a bash file
sh filename.sh
or if you make it executable use 'dot-slash'
./filename.sh
PostPosted: Wed Aug 22, 2012 8:44 am  (#6)
Thanks Rich.
