It is currently Tue Oct 20, 2026 2:30 am
 Post subject: Youtube downloading
PostPosted: Sat Sep 15, 2012 11:03 am  (#1)
Is it just me or has anybody else been unable to download youtube videos for the last 2 days? I have 3 downloaders and all are updated and none of them will work. For me this is a major big deal.
 Post subject: Re: Youtube downloading
PostPosted: Sat Sep 15, 2012 11:54 am  (#2)
YouTube made some changes to their system on 09/13/12 that broke most of the download apps. I use Download Helper and here is what they say.
We are aware of the problem that occurred on Sept 14th (13th if you are in the US).
This is due to some changes YouTube just made. We are working hard at solving the issue. Please, give us a little bit of time and refrain from downrating the addon.
UPDATE: we now have a temporary workaround. It is available from http://www.downloadhelper.net/install-b ... n=4.9.10b6
PostPosted: Sat Sep 15, 2012 12:37 pm  (#3)
I just tried with freemake video converter and it worked
PostPosted: Sat Sep 15, 2012 4:17 pm  (#4)
I used to use that, but after a while I had 5 or 6 video downloaders I had to eliminate some, that was one I scrapped. Maybe I should keep more than 2 onhand.
PostPosted: Sat Sep 15, 2012 4:48 pm  (#5)
I just downloaded freemake downloader. It worked fine and has a lot of features. Thanks.
