It is currently Mon Oct 19, 2026 4:59 am
 Post subject: quick question (for a linux user)
PostPosted: Wed Oct 17, 2012 8:31 pm  (#1)
if i wanted to install fedora would i have to uninstall windows first? or can i install fedora from the cd then delete the partition after?
 Post subject: Re: quick question (for a linux user)
PostPosted: Wed Oct 17, 2012 8:40 pm  (#2)
I have a multi-boot laptop with windows7 and Ubuntu 10.04
I made sure I had room for my linux (windows must be installed first. and usually is)
then installed ubuntu.
I would imagine fedora is just as easy to install, but I would check out the fedora Live CD site (I assume there is one) for the steps just to give yourself confidence.
PostPosted: Wed Oct 17, 2012 8:46 pm  (#3)
i've done that, i'm running the live cd right now but i don't really need two OS and want to uninstall windows (it's getting on my last nerve i spend more time fixing it then anything else!!!)
PostPosted: Wed Oct 17, 2012 8:46 pm  (#4)
Run the Fedora installation CD on system reboot - it will uninstall Windows, no partition is needed. If you already have a dual-boot system with partition, uninstall Linux and run CD all the same.
I've done that couple of times on my laptops before Oracle came up with Virtual Box machine.
PostPosted: Wed Oct 17, 2012 8:55 pm  (#5)
oh ok thanks K1TesseraEna
