It is currently Tue Oct 20, 2026 12:57 pm
 Post subject: Windows 7 vs Windows 8
PostPosted: Sat Dec 15, 2012 7:26 am  (#1)
Has anyone here experienced Windows 8 yet? If so, feedback would be appreciated.
It seems to me that almost all the places now are stocked with Windows 8. I have heard good and bad.
The reason I am asking is I have to get a second desktop tower and before I do I would like to know if Windows 8 is something to stay away from at this time.
 Post subject: Re: Windows 7 vs Windows 8
PostPosted: Sun Dec 16, 2012 1:36 am  (#2)
All signs indicate that you should stay away from it.
If you buy a windows 8 computer, make sure that it has a way of turning off secure boot, because otherwise you might be buying a very expensive brick.
PostPosted: Sun Dec 16, 2012 4:34 am  (#3)
Thanks dd.
PostPosted: Sun Dec 16, 2012 8:34 am  (#4)
It depend from country to country but i believe that if you chose 7 you will also get a chance to upgrade to 8 at a promotional price (in case you want try 8)
But knowing MS i will stick with 7, till 8 will be sufficently patched, the first relaeses are often buggy
More for some reasons MS usually get 1 good hit every 2 release :
Win 2000 was crap,Xp was goods, vista a disaster, 7 fine ...if so 8 would be ...
PostPosted: Sun Dec 16, 2012 3:18 pm  (#5)
like playing the odds huh...
PostPosted: Mon Dec 17, 2012 9:05 am  (#6)
Depends if you include ME or not. That was dreadful.
