It is currently Tue Oct 20, 2026 9:03 am
 Post subject: Cool System Info Script For Linux: inxi
PostPosted: Mon Dec 24, 2012 2:32 am  (#1)
http://code.google.com/p/inxi/
For full verbosity..
./inxi -F -v7
Results on this system. (yeah, it's kinda old). :hehe
 Post subject: Re: Cool System Info Script For Linux: inxi
PostPosted: Mon Dec 24, 2012 9:22 am  (#2)
Didn't install, command not found.
[root@localhost ~]# cd /usr/local/bin && wget -Nc smxi.org/inxi && chmod +x inxi
bash: wget: command not found...
chmod: cannot access `inxi': No such file or directory
PostPosted: Mon Dec 24, 2012 11:57 am  (#3)
Hi O,
This means your system is missing the wget program.
Besides this would d/l a deb file which AFAIK Fedora cannot install.
It's a bash script however and that should run on any flavor of linux.
http://code.google.com/p/inxi/source/br ... ec=svn1717
Scroll down to "View raw file" and click it.
On my system Gentoo Linux) I get a pop-up asking to d/l it.
You'll have to unpack it and you'll get 2 files:
*inxi (the script) and inxi.1.tar.gz which is the manual.
Hope this helps.
It runs fine on my Gentoo system.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Mon Dec 24, 2012 1:11 pm  (#4)
Thanks, Gerard. I'll give it a go.
Did find wget in the add/remove programs for Fedora so have added that.
PostPosted: Mon Dec 24, 2012 2:23 pm  (#5)
It's a shell script. You can place the script anywhere in your path or just drop it in your user folder and run it from there.
I'm attaching a copy of the current version, as of today.
File comment: inxi - Linux System Info Script
inxi.zip [83.04 KiB]
Downloaded 116 times
