It is currently Wed Oct 21, 2026 7:46 pm
 Post subject: I need help to archive and order web pages
PostPosted: Wed Jan 23, 2013 10:44 pm  (#1)
I want make a archive of parameters (with related examples ) and so i need to QUICKLY save from pages as http://soldeus.deviantart.com/gallery/? ... /#/d5sf5c2
1 the image (not strictly needed the full size to download, that displayed on the page may suffice
2 the image comment (where are the parameters )
3 the page link (for trace the credit in case the parameters are used for tweaks )
4 to assign tags to make a search possible
Image and image comment may be saved on 2 different files and format BUT with same name in same place, tags may be assigned to the images or to the images comment , will not make difference since they should have same names (and differ for the file format )
No idea how to do ... suggestion ?
 Post subject: Re: I need help to archive and order web pages
PostPosted: Thu Jan 24, 2013 12:10 am  (#2)
I'm not sure but HTTrack might be what your looking for.
PostPosted: Thu Jan 24, 2013 12:24 am  (#3)
Doesn't GIMP 2.8 have a File>Create>From Webpage? Creates a snapshot of the entire page. One file, one name.
PostPosted: Thu Jan 24, 2013 12:43 am  (#4)
yes but how how embed the page link and add tags ?
PostPosted: Thu Jan 24, 2013 12:57 am  (#5)
You want a server/web-based archive or PC archive with clickable URLs, and tags to navigate through archive?
PostPosted: Thu Jan 24, 2013 1:42 am  (#6)
AFAIK, you can't embed a clickable URLs or tags into image stored on your computer, but it's possible with Adobe PDF file format.
PDF can be opened with browser, here's your link. Not sure about tags in PDF, I think not.
If you need just URL info you can store metadata like this in jpegs and tiffs.
But you're gonna need to open it with a program (GIMP) that can read that data.
PostPosted: Thu Jan 24, 2013 11:06 am  (#7)
This program will DL the entire website if you want. When you run it in your browser, it will as if it is on the web, but it is on your hard disc.
PostPosted: Thu Jan 24, 2013 12:36 pm  (#8)
i know HTTrack it is quite cool but i don't want download the whole side would be even impossible in this cases (Deviantart )
To explain better what i need is to found how open (OR more simply to save) all the pages of my Favorite
Well from the page i need only the "main" image the image comment and the link to the page
and i need to tag, totag i should see the image to tag, and would be a nightmare if all images would be enclosed in xxx-image-folders (corresponding to the xxx,html file of the page ) to be opened one by one ...also in each of that "image" folders would be dozens of other irrelevant images to delete, because they will just add mess and eat disk space
But to make it clear this is a example http://soldeus.deviantart.com/gallery/? ... /#/d5sf5c2
i would need to save from there ONLY this http://fc02.deviantart.net/fs71/i/2013/ ... 5sf5c2.png (the main image displayed ) but not the others
and then to get the image comment
in this case
The Metallic Hallsby *Soldeus
Digital Art / Fractal Art / Raw Fractals ©2013 *Soldeus
The Metallic Halls
Created with Mandelbulb3D 1.8.
Thanks for comments and favs. :)
Mandelbulb3Dv18{
b......1...U5...w....2U....PGDcpXPtzzotnKXHIfn5ECOs2cf1qewHrSbMvj/Q3.FNLvATSW/.E
................................MyKpb0Ka7/2........Y./..................y.2...wD
...Uz.....Ul8....M.1/.....U98...a0...2E3.....sjE7tR.qliD/..........m.dkpXm1.OaNa
z.....cD12..0..........wz..................................u1....y1...sD...../..
.zXaNadDb2VtP5URgvv1G4/irtHQvmzXYabgERVDlC/haQGtKsv/0TzrvBMlyOHqiYYimjij2H6AJgvb
lrHo5QsGu8zuymPkdsxS1KgD......YL/2............sD.6....sD.2E.....................
.............oAnAt1...sD....z.rbwC.2Umv.k08j1.JcwC.wVmv.E88j1.ncwC......G....k1.
.....AQxcz1.......kz.wzzz1UU.U2.L....20...UB....M0...Q2...EE....1/...I1.....SH52
..UU.0aZczDM6/nz....zXWEc/6./c..zzzz..EbG7eFT5uj4U.Ehl2Ilz1...........E28.U9q.5.
.odIWOorVy9.qIU1bNlyz0........../EU0.wzzz1...........s/...................E.2c..
zzzz.............0...................2./8.kzzzD...........U8....................
/EU0.wzzz1...................................wTq41kxsXDyee0k.1A.PnBrQHJJwXSe.IDv
DLDmxVTVR..zxK6zQs5y3q/.rW7Tr0bTsLM5.sTvRvDlyVTVR..mjx/mMw5y3q/.YSbHYmqTsLM5.kzv
XnDkzVTVR.UwMzfw..EzOjPsee0k.1AkIJ3zdr8uwy5y3q/b.ELMmB56ms0QiR4.h6LNbZqPipGAi.bP
E....A....E.....I....k....EEh3aSdtqN0x4Sm.UQ..........................k/.MU/4...
.ok.1.....UNaNaNaNayz.........yDBnAnAnAnUz1.....................................
...sz..............................wz...........................................
.....................2.....3....0....wZFjl4NdtqNIJ4Rm3qAY/......................
06.............................E..........2.....................................
................................0....E/....1....BJaPbJaQ9xqMcNZA................
................4MU/4MU/........bNaNaNaN3.2BnAnAnAntzAnAnAnAnAvjNIJJJJJJJz1.....
...................................................................wz...........
and save together , embedding, (even as added line of text i don't mind how) the page link
Now i should repeat this for all images here http://photocomix2.deviantart.com/favourites/48052512 that are gazillions so it would be cool a method to open and save automatically one by one
Then later i will need to browse and add tags.
DownThatAll !!
maybe DownThatAll that is a Firefox extension may do the trick
checking now http://www.downthemall.net/howto/features/
PostPosted: Thu Jan 24, 2013 1:17 pm  (#9)
HTTrack is customizable, it can be set to different level. The best part is it builds a central page linked to all your downloaded pages even when you download individual sections. Firefox or Chrome can save webpages with graphics in a separate folder, a bit time consuming if you have many pages though. How many pages do you need?
PostPosted: Thu Jan 24, 2013 8:38 pm  (#10)
That is the problem, thousands
and saving as you suggested each image will be enclosed in a folder making a nightmare browse the images...because the main point is that the text part will say anything to me, all is value depend to be directly connected to a image
Let 's try to explain better are the images that i need to save ,browse, a organize, is for images i will search...only when i found the images become important the text part with the formula , the author name and the page link
Odinbc back to your suggestion seems good but you have a idea on how to make the set up, as example if would be possible instead then save the full web page save only the image and the image comment as plain text (and so filter out the dozens of other images, ads, and unrelated links that are in any page )
Even FF "scrapbook" does a excellent job in save , and tag and organize and even export web pages, the only problem is that doesn't allow me to browse the content for images (may be some trick to do it that i don't know )
PostPosted: Thu Jan 24, 2013 9:11 pm  (#11)
Have you downloaded WinHTTrack? If not go to their web site and look at the Shell Documentation. Read both the Step-by-step example and Option panel. There are too many options and filters for me to tell you about, you will be better off reading the documentation yourself.
PostPosted: Sat Jan 26, 2013 10:13 am  (#12)
Yes ,i fear i will have to read all that docs , thank for the tip
