It is currently Tue Oct 27, 2026 4:30 am
 Post subject: Laptop Battery
PostPosted: Fri Nov 15, 2013 10:41 pm  (#1)
My HP Pavilion g7-1310us Notebook battery is losing life. I did the battery check and it says I should calibrate it. I've never calibrated a battery before. When I had my first HP laptop that ran on XP, I hadn't done it. All I did was just replace the battery. For my HP Pavilion laptop should I calibrate the battery or just replace it with a new one?
 Post subject: Re: Laptop Battery
PostPosted: Sat Nov 16, 2013 1:22 am  (#2)
Check at HP, Testing and Calibrating the Battery and Battery information center.
PostPosted: Sat Nov 16, 2013 1:36 am  (#3)
Odinbc wrote:
I have. My question was, should I calibrate the battery or just replace it?
PostPosted: Sat Nov 16, 2013 2:31 am  (#4)
mackenzieh wrote:
Why not try the calibration. If it makes no positive difference, then replace it.
PostPosted: Sat Nov 16, 2013 3:27 am  (#5)
fluffybunny wrote:
Thanks, fluffybunny. I will try the calibration.
