It is currently Sun Oct 25, 2026 12:09 am
 Post subject: REDUNDANT THREAD
PostPosted: Thu Nov 21, 2013 3:28 pm  (#1)
VIDEO REMOVED
 Post subject: Re: Free painting video
PostPosted: Thu Nov 21, 2013 4:57 pm  (#2)
Downloaded without a hitch Eris. Great vid.
You are very good at drawing faces, keep up the good work.
Question: What does painting in all that black do after you had already finished that part? Whatever it was, it was effective.
PostPosted: Thu Nov 21, 2013 5:03 pm  (#3)
Erisian wrote:
I was testing some video capture and video editing software and ended up making a short (1/4 hr) video. It's not a complete painting and there is no sound but you are welcome to download a copy from:
http://www.filefactory.com/file/1c8cx0txgtx5/Video_Software_test_01.zip
This is NOT my previous Mediafire account - I'm through with Mediafire! The video is in a zip and the download size is about 47 MB. Just follow the link and scroll to the bottom of the page then click on the red SLOW DOWNLOAD button. You will have to wait about 30 seconds before you can download the file.
Hi Erisian,
Molly tells me this is worth a look, but I click on the red slow download button. The screen scrolls back up to the top of the page. I wait and wait. 3 mins, nothing is happening? It worked for molly so it must be my browser.
Will try again later and let you know if I have any success.
PostPosted: Thu Nov 21, 2013 5:05 pm  (#4)
Thanks Molly. If you are referring to the shoulder pieces, the idea of the black was to separate the armour from the rest of the outfit.
Fluffybunny. What browser are you using? I think Molly uses Firefox.
PostPosted: Thu Nov 21, 2013 5:09 pm  (#5)
Fluffy, I saved it to downloads, not Gimp. Did you try looking in your downloads.
PostPosted: Thu Nov 21, 2013 5:11 pm  (#6)
I use IE11.
I also have a portable version of Chrome on a memory stick somewhere. I'll dig it out and let you know what happens.
Edit: Worked fine with Chrome.
:tyspin :bowdown
It is embarrassing to see how effortless you make this look.
I spend more time with the eraser than the brush.
I know that praise from a beginner is diminished compared to praise from one of our many other talented artists, but I take my hat off to you sir. (If I wore a hat that is) ;)
PostPosted: Thu Nov 21, 2013 6:14 pm  (#7)
I didn't see this for a while because new edits don't show as new posts. I'm flattered you think so highly of my ability. I'm glad you managed to download it eventually. Thank you for your comments.
PostPosted: Fri Nov 22, 2013 11:34 am  (#8)
IMAGE REMOVED
PostPosted: Fri Nov 22, 2013 2:26 pm  (#9)
If you downloaded an exe instead of a zip, look at the first post again. I have edited it with further instructions. I apologise for not knowing about this before.
PostPosted: Fri Nov 22, 2013 2:58 pm  (#10)
works perfectly now Eris, How was I supposed to know this. I am going to sic AnMal on you.
PostPosted: Fri Nov 22, 2013 3:00 pm  (#11)
Please don't make her any worse than she already is! :hehe
PostPosted: Fri Nov 22, 2013 3:41 pm  (#12)
I wanna download but I'm waiting for internet to renew still. lol
PostPosted: Sun Nov 24, 2013 6:40 pm  (#13)
VIDEO LINK REMOVED
PostPosted: Mon Nov 25, 2013 11:43 am  (#14)
wooooooooo I'm watching it, I like it I like it! :3
The Sketch looks better than my faces I draw that are finished. :lol :D
PostPosted: Mon Nov 25, 2013 12:07 pm  (#15)
:hi5 :) :tyspin Thank you Moko.
