It is currently Mon Oct 26, 2026 3:31 am
 Post subject: Anyone here know how to get itunes to work? :S
PostPosted: Thu Dec 19, 2013 4:46 pm  (#1)
I was recently given an ipod shuffle and I can't seem to get itunes to work.
It seems I installed a scam first then I had to uninstall for 40 things it installed and I found out I installed wrong version of itunes anyway I had to install 64 bit not 32......
So I tried to install 64 but I can't get it to download, I downloaded it once and it didn't work it said it's 32 when is was 64, then I tried to download again and it won't download...
Can anyone help me out here? Or anyone ever had this problem before? :S
Thanks! :tyspin
~ God Bless ~
~ Moko
 Post subject: Re: Anyone here know how to get itunes to work? :S
PostPosted: Thu Dec 19, 2013 5:24 pm  (#2)
For Windows I recommend using MusicBee instead of iTunes to manager your iPod.
PostPosted: Thu Dec 19, 2013 5:44 pm  (#3)
itunes now wants to work but I might look at that other thingy.
:tyspin
PostPosted: Thu Dec 19, 2013 5:53 pm  (#4)
:tyspin
MusicBee is an elegant replacement for iTunes.
If you decide to stick with iTunes read this,
The unofficial guide to installing iTunes 10 without bloatware.
PostPosted: Thu Dec 19, 2013 6:27 pm  (#5)
iTunes doesn't wanna see my shuffle so I think I'm going with the thingy you posted...:gaah
