It is currently Tue Oct 27, 2026 4:22 pm
 Post subject: This guys cable renders have to be seen ....
PostPosted: Mon Jan 06, 2014 11:57 am  (#1)
...in order to be appreciated. Don't think I can ever render something like these. A friend from Flickr (and elsewhere) PMedme the link. I'm in awe. :)
http://www.flickr.com/photos/tsevis/117 ... 99232@N00/
 Post subject: Re: This guys cable renders have to be seen ....
PostPosted: Mon Jan 06, 2014 12:24 pm  (#2)
I have confidence you can do it, probably something better. :hehe
PostPosted: Mon Jan 06, 2014 12:43 pm  (#3)
:ninja by tux
amazing pictures Lyle. thanks for sharing.
PostPosted: Mon Jan 06, 2014 2:20 pm  (#4)
Nice!
It looks like something that might be able to be done using G'Mic. Would be interesting to find out if it could be done this way.
PostPosted: Mon Jan 06, 2014 2:50 pm  (#5)
all of his work is amazing, such an imagination as well as great talent.
PostPosted: Mon Jan 06, 2014 3:02 pm  (#6)
Heck of an imagination. Awesome work.
PostPosted: Mon Jan 06, 2014 5:33 pm  (#7)
I've been wanting (secretly) to be able to do such renderings since seeing the T. Rowe/Price commercials (remember the GIMPressionist Rice preset?). Now this guy actually can do these and he hinted that he uses scripts and a bunch of other things ; a labor of love he says. I have no idea how it's done since I'm just a poser. lol
Oh well; guess the oriental in me am happy I perfected rice anyway. :)
PostPosted: Mon Jan 06, 2014 6:02 pm  (#8)
So what I gather for what you're saying is that it's possible to do this, somehow with Gimp. He must have came across some kind of script combination that does wonders.
Very interesting...
PostPosted: Mon Jan 06, 2014 6:09 pm  (#9)
Have some rice on me Wallace. :)
PostPosted: Mon Jan 06, 2014 6:16 pm  (#10)
:hehe
PostPosted: Mon Jan 06, 2014 8:35 pm  (#11)
yikes, looks like maggots with my bad eyes!
PostPosted: Mon Jan 06, 2014 9:04 pm  (#12)
Only can appreciate these at high rez 2-ton. :)
PostPosted: Mon Jan 06, 2014 9:42 pm  (#13)
Hey Lyle have you tried out the new Mycellium Filter by Bootchk?
Probably won't give great as results as those but it has a wormy effect and may be a starting point. :)
Good luck with this however you pursue it. I am sure you will get awesome results as usual. ;)
On the other hand a wire lines may not be a hard filter to write. :)
If you can find the lines in an image (ie Edges>Neon) or other. You could then manipulate those lines by say smoothing them? I will have to look into an algorithm for this effect. :hehe . Possibly you could manipulate a Gimpressionist brush within a script to follow those neon edges also. Some possibilities there.
Actually it looks like there is a frame that he starts from (larger wires/cables), and then adds on the smaller stuff.
PostPosted: Mon Jan 06, 2014 11:25 pm  (#14)
White or brown? There is a cooking difference. :P :hehe
PostPosted: Tue Jan 07, 2014 11:43 am  (#15)
Only like white rice Moko; brown rice tastes like rubber to me. lol
PostPosted: Tue Jan 07, 2014 11:52 am  (#16)
Wow that looks like rice for sure, Just glad it isn't brown rice, might as well eat gravel.
PostPosted: Tue Jan 07, 2014 11:58 am  (#17)
GIMPressionist and some G'MIC tricks Molly. Very simple. Thanks for the comments. :)
PostPosted: Tue Jan 07, 2014 11:09 pm  (#18)
I prefer white rice myself, but brown rice is better for you. :lol
