It is currently Tue Oct 27, 2026 4:22 pm
 Post subject: Dust, flying rock particals
PostPosted: Tue Jan 14, 2014 8:01 am  (#1)
Hi,
Does anyone know where I can get some good free stocks of dust particles and flying rocks? I could not find much on google.
I would like to create exploding effects on objects in space.
Thanks.
 Post subject: Re: Dust, flying rock particals
PostPosted: Tue Jan 14, 2014 9:09 am  (#2)
If you want i can render a few in Filter Forge 3 Pro. :)
http://filterforge.com/filters/search.h ... osion+&h=r
Just pick the ones you like. You can also search for more and just give me the links to the ones you like.
PostPosted: Tue Jan 14, 2014 1:05 pm  (#3)
Here are some links that might be of some help...
http://www.deviantart.com/art/explosion-167164606
http://www.deviantart.com/art/4-Explosi ... -258733615
http://www.deviantart.com/art/Debris-Br ... -104719100
http://www.deviantart.com/art/PNG-Set-S ... -193524120
http://www.deviantart.com/art/Very-Larg ... -308096593
PostPosted: Wed Jan 15, 2014 1:03 am  (#4)
Thanx alot from you both.
What I want is exactly in the fourth link and my explosion will be more like this one here. However, I cannot find the PNG from the link given on deviantart. Alternatively, I may have to use some resources from google search.
Stay well.
PostPosted: Wed Jan 15, 2014 1:21 am  (#5)
as png http://frostbo.deviantart.com/art/4-Exp ... -258733615
but he as much more Png( and many space brushes too ) http://frostbo.deviantart.com/
:ninja ohh i see you already found
PostPosted: Wed Jan 15, 2014 1:42 am  (#6)
Stay well.
Okay, good luck. ;)
PostPosted: Wed Jan 15, 2014 2:14 am  (#7)
Nice post!
