It is currently Sun Oct 25, 2026 8:02 am
 Post subject: the effects hub
PostPosted: Sat Feb 08, 2014 1:59 pm  (#1)
Has anyone seen this website? http://www.picturetopeople.org/
it's a
 Post subject: Re: the effects hub
PostPosted: Sat Feb 08, 2014 7:54 pm  (#2)
Excellent resource. Thank you. :)
PostPosted: Sat Feb 08, 2014 7:59 pm  (#3)
You're welcome Rod!
I think the whole thing works similar to PS
PostPosted: Sat Feb 08, 2014 8:00 pm  (#4)
wow that is amazing Kit.
PostPosted: Sun Feb 09, 2014 1:25 pm  (#5)
That's pretty cool, and they do it all for you.
PostPosted: Sun Feb 09, 2014 4:27 pm  (#6)
it seems to work great, but it feels like cheating, lol.
PostPosted: Sun Feb 09, 2014 9:06 pm  (#7)
for those who still don't know much about Gimp or PS it must feel like a magic, lol
PostPosted: Sun Feb 09, 2014 9:52 pm  (#8)
I checked out, www.picturetopeople.org, but I didn't try it out.
It looks like a massive project.
PostPosted: Sun Feb 09, 2014 10:03 pm  (#9)
PostPosted: Sun Feb 09, 2014 10:43 pm  (#10)
It does sort of feel like cheating but I really like it. Great find!
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Mon Feb 10, 2014 7:02 am  (#11)
How can we save the logo generated by P2P? I saved it in the usual way (save as) with the right click of the mouse. Apparently, he was saved, but when I try to open in GIMP nothing appears.
PostPosted: Mon Feb 10, 2014 11:16 am  (#12)
I did exactly as you've described and no problems whatsoever. Can you see the downloaded image with the image viewer?
In addition you can check the Get as a transparent PNG file box and after you hit Calculate Effect the download starts automatically.
PostPosted: Tue Feb 11, 2014 6:51 am  (#13)
Yes, k1. I see the image downloaded, but I can't save it. ????
PostPosted: Wed Feb 12, 2014 2:31 am  (#14)
Hi.
My name is Leonardo. I'm the P2P developer.
This little problem saving the result images is the most common doubt users have.
Most browsers get confused when you use the "save" command from a P2P resulting page. If I use it from my Chrome, for example, it tries to request the image again, what it can not make properly this time. In fact, it should save the local image it's already showing to you, but it doesn't make it. This way, what it saves for you is a HTML error page, what obviously is not your image. Other browsers have some strange behaviors too, and sometimes it also depends on the browser configuration.
Any user who has this kind of problem should copy the image from browser to a desktop graphic program (GIMP in your case) and so save the image as desired.
This subject (image saving) is also cited in P2P "how to use" page. It's a good place to get generic info about how the whole project works (click the second top tab at P2P site).
I have a very big amount of new tools in my schedule to develop for this project, so P2P site will grow a lot yet (probably it will become at least three or four times bigger).
See you!
PostPosted: Wed Feb 12, 2014 5:32 am  (#15)
Carlos,
by using IRON as browser, right clicking and "saving" works perfectly, no problems
PostPosted: Tue Mar 18, 2014 7:23 am  (#16)
leocda wrote:
Hi.
See you!
Welcome to gimp chat leocda
PostPosted: Tue Mar 18, 2014 9:51 am  (#17)
Yes, it's a page when everybody can learn something. Thanks K1TesseraEna.
PostPosted: Tue Mar 18, 2014 2:29 pm  (#18)
Thank you, Molly.
