It is currently Tue Nov 10, 2026 6:28 am
 Post subject: Web Design Icon Using Font-Awesome
PostPosted: Tue May 13, 2014 10:29 pm  (#1)
Hi, I'm a new member and this is my first post.
I mostly use gimp for web design, so in each of my design there always (almost) use icon.
For example, setting icon, profile icon, calendar icon, select caret, etc.
So, my question is obvious, can we use font-aweseome in gimp?
Or maybe, another way to use icon by using unicode font?
Thanks,
kiddo_13
 Post subject: Re: Web Design Icon Using Font-Awesome
PostPosted: Wed Jun 04, 2014 6:50 am  (#2)
You need to upload the font's in your computer's system. Just be sure to get the ones which are free or get license for it.
