It is currently Tue Nov 10, 2026 7:20 am
 Post subject: HTML Image Page Builder
PostPosted: Fri Apr 20, 2012 6:28 pm  (#1)
This little program is just too cool :cool
http://www.sulaco.co.za/downloads.htm
HTML Image Page Builder, last program on the page.
 Post subject: Re: HTML Image Page Builder
PostPosted: Fri Apr 20, 2012 6:41 pm  (#2)
For fun I validated a page generated by HTML Image Page Builder at W3C.org.
7689 Errors.
"document type does not allow element "FONT" here"
I suppose a good find and replace script and some CSS would bring it to up today's standards. This program was made in Jan 2001.
PostPosted: Sat Apr 21, 2012 6:46 am  (#3)
I wish it worked that would be friggen amazing. :D
PostPosted: Sat Apr 21, 2012 10:02 am  (#4)
I have an online generator here. :)
http://simply-signage.com/ImageEditor/AsciGen/index.php
For output mode just select table.Be sure to also set cell width and height to 1 pixel.
You get something like this - the top one is the actual image, and the bottom one is HTML color hex codes in a table. :)
Pretty cool huh?
PostPosted: Sat Apr 21, 2012 11:55 am  (#5)
Yup, I like that one!
PostPosted: Sat Apr 21, 2012 12:14 pm  (#6)
zip attached with html page.
arnie2.zip [35 KiB]
Downloaded 282 times
PostPosted: Sat Apr 21, 2012 12:51 pm  (#7)
ZWard117,
The way it is now "HTML Image Page Builder" would be fine if you just take a screen shot of your results. Just for fun I'm still going to work on a regex to try to bring it up to W3C standards. I already ran one result through HTML Tidy but haven't validated it yet. The doctype I use may help with validation as well.
Rod's "online generator" is be the best way to go right now if someone wanted to post results to a website.
I love this stuff!
