It is currently Tue Nov 10, 2026 7:48 am
 Post subject: GimpChat avatar
PostPosted: Fri Aug 31, 2012 11:12 am  (#1)
Hi there,
As you probably know, GimpChat allows to display avatars as .gif animated files, with a limit of 390Kb.
So, today, I was wondering how a complex avatar I could make, while fitting the limited file size. Here is my attempt, with an animated avatar that takes exactly 390Kb :yes
It is composed of 32 150x150 frames of an animated 3d cube where each face is itself animated (picture rotation + blur), all running at 15 fps.
The trick here was to find a way to do only an half-rotation of the cube (180°), while making the faces of the cube perfectly matching each-other, so that the animation looks smooth.
I admit I didn't use GIMP for this one, except for saving the frames as an animated GIF. I mainly used a G'MIC script I wrote especially for this occasion (source can be found here : http://pastebin.com/x8sQdXta).
What do you think about it ? Anyone interested to start a GimpChat avatar contest ? :geek
EDIT : In case of future avatar changes, here is the one I've originally posted :
 Post subject: Re: GimpChat avatar
PostPosted: Fri Aug 31, 2012 11:27 am  (#2)
You would probably just win anyway. :mrgreen:
Cool Avatar!
PostPosted: Fri Aug 31, 2012 12:09 pm  (#3)
David, was that a script or plug-in you posted in that link? or something else.
PostPosted: Fri Aug 31, 2012 12:53 pm  (#4)
Excellent gif, is something hypnotic :blind
I've been able to reduce the size (~310Kb) without reducing the quality much using:
PostPosted: Fri Aug 31, 2012 1:12 pm  (#5)
Thanks. Interesting YAFU, I was not aware of this gifscile tool.
PostPosted: Fri Aug 31, 2012 1:14 pm  (#6)
Yes, molly, this was a script code in the G'MIC language. You need 'gmic' (the command line tool of G'MIC) installed in order to use it.
Maybe I can add it to the plug-in as well, if you really want to have a try easily.
Let me know (it is somehow long to render by the way).
PostPosted: Fri Aug 31, 2012 1:17 pm  (#7)
Very cool avatar David. I've read up on gifsicle; cool that you can have more then just 256 colors in an animated gif using this tool as well. :)
PostPosted: Fri Aug 31, 2012 2:33 pm  (#8)
Very nice, David. I vote for yours. :)
PostPosted: Fri Aug 31, 2012 3:41 pm  (#9)
:oops: :oops: It is okay, I just wondered cuz I copied it and saved it as a script and it didn't work so I thought maybe it was a plug-in. :oops: :oops:
PostPosted: Fri Aug 31, 2012 3:57 pm  (#10)
thats very clever
PostPosted: Fri Aug 31, 2012 9:00 pm  (#11)
I do hope that you will put that into a G'Mic update!
PostPosted: Sat Sep 01, 2012 1:21 am  (#12)
Nice avatar David! :)
PostPosted: Sat Jun 15, 2013 3:47 pm  (#13)
Would love to see it incorporated. Really cool animation.
PostPosted: Sat Jun 15, 2013 5:01 pm  (#14)
I always wanted to be able to do this, also, Warrior. I don't know how to use the g'mic command line tool, either.
Seems there are a few neat things right now that require that command line tool. I have no idea how it works.
This is an older post...not sure if it would be revisited for consideration as a regular option somehow.
I realized it was an older post. Still hopeful though, haha.
PostPosted: Sun Jun 16, 2013 9:58 am  (#15)
Sequences>3D Image Object.
PostPosted: Sun Jun 16, 2013 10:14 am  (#16)
I made something similar once, using the same feature. I like how the OP's moves, and the photo spins at the same time. Really cool.
