It is currently Mon Nov 23, 2026 1:44 am
 Post subject: Got my bling working!
PostPosted: Wed Dec 22, 2010 11:32 am  (#1)
LOL ... i had to download gimp portable 2.6.11, copy all the scripts in the scripts folder and replaced all the scripts in my 2.6.11 program with those.Now i have a folder with pulled from 2.6.11 folder scripts (about 400).
I decided to start testing which scm's were throwing conflicts, as i had many.
I placed the animated snow script in and refreshed gimp and it worked!
So now i will keep adding them one at a time until i figure out which ones are not working in 2.6.11
On the good side my Gimp loads 5x faster now! :rofl
 Post subject: Re: Got my bling working!
PostPosted: Wed Dec 22, 2010 11:38 am  (#2)
Check for GURM will help to mantain script and addon organized
PostPosted: Wed Dec 22, 2010 11:41 am  (#3)
Yeah i have GURM installed already.It does work great.I want to isolate the scripts that don't work with 2.6.11 though.
Once i do that then all my scripts will go into GURM scripts folders...the ones that work with 2.6.11
cron
