It is currently Fri Sep 25, 2026 9:41 pm
 Post subject: Do you know of a good photo collectors forum?
PostPosted: Tue Feb 08, 2011 8:48 pm  (#1)
I am looking for a good forum that is devoted to collectors of old photographs who want to discuss history, type, method, conservation and restoration, etc.
Anyone found a good forum?
 Post subject: Re: Do you know of a good photo collectors forum?
PostPosted: Tue Feb 08, 2011 8:54 pm  (#2)
Have you searched the Flickr groups? It's the most popular site for photographs (at this present time) I am sure somewhere in the vastness of Flickr there is such a group. First start out by going on Flickr and searching for old b&w photographs as a search item, it might lead to a group. Just an idea.
My search yielded:
http://www.flickr.com/search/groups/?w= ... hotographs
PostPosted: Thu Feb 10, 2011 6:21 am  (#3)
You may want to have a look at http://www.retouchpro.com The site is dedicated to retouching and restoration of photographs. It is heavily Ps orientated , but it is very instructive as to the methods involved. Most of the methods are easily reproduced in Gimp.
I have been on that site on and off for a good two years , never posted , but learned plenty!
Definitely worth a look!
PostPosted: Thu Feb 10, 2011 7:46 am  (#4)
I would most def try Flickr first. :)
Their database is humongous!
PostPosted: Thu Feb 10, 2011 12:52 pm  (#5)
Retouchpro.com looks like what I'm looking for. Thanks.
