It is currently Tue Nov 17, 2026 9:14 am
 Post subject: Photo enhancement request
PostPosted: Wed Sep 23, 2015 4:49 am  (#1)
Hi,
Let's light up a photograph using Gimp only from the first photograph to the second one below.
Happy Gimping.
File comment: From this
File comment: To this
 Post subject: Re: Photo enhancement request
PostPosted: Wed Sep 23, 2015 5:58 am  (#2)
A couple of attempts from me, using the saulgoode luminosity masks to limit the effects to certain brightness regions.
david.
PostPosted: Wed Sep 23, 2015 6:19 am  (#3)
1 attempt from me just using the equalize filter. Pity it doesn't have settings to change
PostPosted: Wed Sep 23, 2015 6:23 am  (#4)
Here's my try...
PostPosted: Wed Sep 23, 2015 6:25 am  (#5)
Thanx for your feedback.
Here is my result also. I only used the Adjust Color Levels:
The original work from https://home.regit.org/2012/04/doing-mi ... -and-gimp/
Cheers.
PostPosted: Wed Sep 23, 2015 6:29 am  (#6)
only using LumaInvert
(deleted, duplicated insert..., see below)
PostPosted: Wed Sep 23, 2015 6:29 am  (#7)
I also tried equalize shadow in G'MIC. The other is gimp's auto under colour.
PostPosted: Wed Sep 23, 2015 6:30 am  (#8)
PostPosted: Wed Sep 23, 2015 6:55 am  (#9)
In this one I added curves after equalize to bring the highlights on the white especially down
PostPosted: Wed Sep 23, 2015 7:16 am  (#10)
Everybody failed to reproduce the weird halos in the model picture :)
PostPosted: Wed Sep 23, 2015 7:24 am  (#11)
Thank you all for sharing your pressures time with me here.
:jumpclap :tyspin :gimp
Joseph
PostPosted: Wed Sep 23, 2015 8:27 am  (#12)
So long as using G'MIC isn't cheating, I did it all in GIMP. Not a pretty result though. Thanks for the challenged play Joseph. :)
PostPosted: Wed Sep 23, 2015 10:44 am  (#13)
Another go.
Image Image
Decompose to LAB, L - Unsharp Mask, A/B - Curves, Recompose
G'MIC - Contrast swiss mask, output New Layer, Screen
w/ G'MIC - Blur [glow] Lab [lightness]
PostPosted: Wed Sep 23, 2015 1:02 pm  (#14)
very nice results, i think! i wasn't too fond of what ofnuts called "weird halos" in the model pictures, but it still seems like a fun challenge to try and reproduce them - if i have the time i'lll give this a try. it would be fun to just try and make look good according to my own tastes too, since it's not my style of picture at all.
PostPosted: Thu Sep 24, 2015 3:56 am  (#15)
Hi,
Fantastic finishing there Odinbc !
Happy Gimping.
:gimp
Joseph
PostPosted: Thu Sep 24, 2015 5:04 am  (#16)
Odin; that's a fantastic result. :)
PostPosted: Thu Sep 24, 2015 4:47 pm  (#17)
Definitely, curves is the way to go. Decided to also do some cloning/healing work as well to get rid of the bright area. :)
PostPosted: Thu Sep 24, 2015 5:07 pm  (#18)
Looks good Lyle.
PostPosted: Thu Sep 24, 2015 10:01 pm  (#19)
Curves, local contrast enhancement, sharpen, with the slightest bit of color tweaking.
PostPosted: Fri Sep 25, 2015 6:49 am  (#20)
Brilliant Lyle. Don't miss the burnt out part of the hood at all.
