It is currently Tue Nov 17, 2026 5:11 pm
 Post subject: Deblurring A Photo
PostPosted: Sat Oct 17, 2015 12:53 pm  (#1)
Trying to use Iterative Refocus, but not having much success. I downloaded Unshake, but having even worse luck with it, as I can't get it to work right, haha. Any heads up as to deblurring a photo? Here's the one I'm trying to make better.
 Post subject: Re: Deblurring A Photo
PostPosted: Sat Oct 17, 2015 1:10 pm  (#2)
Cute chippy, did you try unsharp mask?
PostPosted: Sat Oct 17, 2015 1:14 pm  (#3)
this outcome has been obtained by using Octave Sharpening by David Moreno (there is also a version 2 more flexible)
PostPosted: Sat Oct 17, 2015 1:37 pm  (#4)
Thanks Molly. I spent a week in Vermont last week. Went for a walk, and came across 2 baby chipmunks. I started talking to them, as I always do to animals, and this one came right up to me. Here's a photo my wife took of me, taking this photo:
dinasset, that's a similar result to what I got. I know my results never be perfect, I just always think It can be better, I guess. Maybe that's about as good as it'll get.
PostPosted: Sat Oct 17, 2015 1:53 pm  (#5)
you can try this method to see if it makes any difference...
viewtopic.php?f=23&t=11777&hilit=photo+enhancement#p159130
PostPosted: Sat Oct 17, 2015 4:10 pm  (#6)
Very nice Wallace, thanks. I did everything like you said on the thread, but instead of setting the new from visible layer to overlay, and adjusting the opacity, I set it to grain merge. Nice result.
Before:
After:
Animation showing the difference:
PostPosted: Sat Oct 17, 2015 4:58 pm  (#7)
This is another attempt I did. I used Unshaker this time. Then, I took that result into GIMP, duplicated the layer, sharpened to 40, then set the layer to Value. Before and after:
Animation before and after:
PostPosted: Sat Oct 17, 2015 5:16 pm  (#8)
Those are all really good results Warrior.
I think the one where you used Unshaker came out best.
PostPosted: Sat Oct 17, 2015 8:22 pm  (#9)
It did, but, I really like that technique you posted. :bigthup
PostPosted: Sat Oct 17, 2015 8:37 pm  (#10)
:coolthup
PostPosted: Sat Oct 17, 2015 8:44 pm  (#11)
Ran wavelet decompose and played with some sliders and duplicated other layers from the result, then applied the result selectively. Not a perfect solution by any means. Maybe, if you can figure out the right convolution, a de-convolution approach can be tried, but that's pretty hard to do. :)
PostPosted: Sat Oct 17, 2015 9:30 pm  (#12)
Nice work Lyle. That's the thing with me when it comes to the de-convolution, etc, is that I simply don't understand anything about it. I like the programs that figure it out on their own, haha.
PostPosted: Sat Oct 17, 2015 10:42 pm  (#13)
Me too Warrior; me too. lol
PostPosted: Sun Oct 18, 2015 7:27 am  (#14)
me too, so I wrote a small filter to implement that tut (you know I'm a bit lazy...)
Wallace_style_deblur.7z [1.57 KiB]
Downloaded 355 times
PostPosted: Sun Oct 18, 2015 8:00 am  (#15)
I tried extracting it twice with 7zip, but I get the error message:
PostPosted: Sun Oct 18, 2015 8:09 am  (#16)
strange
try with this .zip version
Wallace_style_deblur.zip [1.55 KiB]
Downloaded 496 times
PostPosted: Sun Oct 18, 2015 8:56 am  (#17)
You can also use the grain extract/grain merge technique but with a motion blur that lines up with the motion blur of the source image. Here was a quick go, I measured the blur at 6px at 66degrees:
-Rob A>
PostPosted: Sun Oct 18, 2015 9:14 am  (#18)
excellent Rob.
How can one measure the motion blur?
PostPosted: Sun Oct 18, 2015 9:37 am  (#19)
That works dinasset, thanks.
PostPosted: Sun Oct 18, 2015 9:39 am  (#20)
OK, glad you got it.
