Hi folks,
I get photos from a smartphone of horses to put on a website... they're pretty poor quality, especially those taken in a stall of newborn foals - and I'm not that experienced in adjusting images so I wind up just shotgunning with curves, levels, contrast/brightness, etc. I have no way to get a better quality initial image - I'm not the one taking the photos. If there is anything I could suggest to the person taking the photos I can do that - but suspect the limitation is the camera phone being used.
I would REALLY appreciate suggestions for the best way to improve these photos.
I particularly would like to be able to get rid of the pixilated edges, the sort of overcast or lack of contrast/highlights, the blurry/unfocused look (maybe created by the pixilation?) - or anything else folks can suggest to make the image look more realistic/better.
Thanks in advance for suggestions!
qv2016f.xcf [232.6 KiB]
Downloaded 225 times
File comment: This is the original file. I rotated it, cropped it, and used the perspective tool a little to fix the vertical distortion, assuming that was the best way to start. If not, this is the original...
