It is currently Wed Nov 18, 2026 1:17 am
 Post subject: Improve photo quality
PostPosted: Thu Apr 28, 2016 10:41 pm  (#1)
Hi everyone, I would like to improve the quality of this image. It is one of my favorite pics of the kids. Anyone know how I can?
 Post subject: Re: Improve photo quality
PostPosted: Fri Apr 29, 2016 2:47 am  (#2)
I think you need to explain what you mean by "quality" as it's a rather vague, subjective term.
So I'll start by asking you what you think is wrong with your original.
Kevin
PostPosted: Fri Apr 29, 2016 3:51 am  (#3)
Is that the biggest size you have?
PostPosted: Fri Apr 29, 2016 4:14 am  (#4)
I just sharpened the image and placed it in a frame
PostPosted: Fri Apr 29, 2016 5:58 am  (#5)
Did you enlarge this photo? Have you got a larger one?
I cannot remove the 'stairs' on her arm unless I blur the photo and then it loses all sharpness.
Is there something else you wanted fixed up?
PostPosted: Sat Apr 30, 2016 4:01 am  (#6)
I did my try on this photo. My steps were: make it larger, then I repaired the boy's eye and some little zones too, after that I applied Tone Map and finished applying unsharp Mask. :)
PostPosted: Sun May 01, 2016 3:01 am  (#7)
For some reason jprado471 replied to me by PM, which isn't the best way to solicit help from the community ;)
jprado471 wrote:
I would like to remove the blur and make it sharper, more detailed.
Kevin
PostPosted: Sun May 01, 2016 9:43 am  (#8)
Thank you Kevin.
PostPosted: Mon May 02, 2016 9:25 pm  (#9)
Cropped and applied 'freaky details'
