It is currently Sat Nov 07, 2026 7:05 pm
 Post subject: how to tell the image quality??
PostPosted: Wed Dec 14, 2016 12:21 pm  (#1)
hi
Is "Resolution" the primary parameter of determining the quality of the image?
For example, given that I have two original images taken from two different mobile devices, how can I tell which one image has better quality in addition to wild guessing by naked eyes?
 Post subject: Re: how to tell the image quality??
PostPosted: Wed Dec 14, 2016 4:05 pm  (#2)
I would load up both images and compare them by viewing at 100% and look the same areas (subject) of the image to compare them.
Generally the one will higher-resolution will look better when you zoom so that they're the same size because the higher-resolution will have more details.
PostPosted: Wed Dec 14, 2016 5:42 pm  (#3)
kenny1999 wrote:
hi
Depends on your definition of "quality" but if quality is "looks good" then a trained eye is a fairly good measurement tool, once you have set them side by side so that the same object is about the same number of screen pixels on both.
PostPosted: Wed Dec 14, 2016 8:11 pm  (#4)
Hallo,
if understand him right he mean that he want object data from sharpens, brightness value and intensity of colour.
Andrew
