It is currently Tue Nov 17, 2026 5:06 pm
 Post subject: G'MIC Film Emulation Preset
PostPosted: Wed Feb 28, 2018 9:15 am  (#1)
As many of you probably know by now I like to restore older photos. I was given this one to make look a bit better. I didn't do much as it looked ok to me , just a bit under exposed) so I tried a GMIC preset and it did this
 Post subject: Re: G'MIC Film Emulation Preset
PostPosted: Wed Feb 28, 2018 10:47 am  (#2)
I think it looses a bit too much of the atmosphere of the original. Maybe blend the original for 30% or something with the new one. It is quite an improvement though. :bigthup
PostPosted: Wed Feb 28, 2018 11:25 am  (#3)
Thank you Vincent
That I could do. What suprised me was it seemed to bring out all the colour I didn't think was there and the correct colours too.
PostPosted: Wed Feb 28, 2018 11:37 am  (#4)
My attempt:
1831_28378619_809359709236458_4224594703531638784_nmontage-dn1.jpg [ 126.65 KiB | Viewed 8114 times ]
PostPosted: Wed Feb 28, 2018 12:02 pm  (#5)
I like yours very much, Dinasset. What did you do?
PostPosted: Wed Feb 28, 2018 12:19 pm  (#6)
Thanks, Pat.
I simply used my filter WhiteBalanceStretch2, in default mode.
I guess you have it among my filters.
PostPosted: Wed Feb 28, 2018 7:32 pm  (#7)
Dinasset: I do have it but it wasn't working properly. I found that I had more than one copy. Deleted one, now working perfectly! I used it on Sallyanne's photo and it duplicated your results, setting on moderate. I'll use this filter more often! Thank you.
PostPosted: Thu Mar 01, 2018 12:40 am  (#8)
sallyanne wrote:
Thank you Vincent
Yes, indeed it did quite a nice job on the color front!
