It is currently Sun Nov 08, 2026 2:36 am
 Post subject: aircraft carrier Historian's nemecis.... Pt 2
PostPosted: Mon May 20, 2019 12:34 pm  (#1)
This image was sent to me by a former Crewman's son but it has fingerprints and surface smudges I haven't been able to "remove" through several editing programs.
I can handle the dust from the slide scan but not the "grease".
Again, I'm guessing that this can be worked out through layers but;
 Post subject: Re: aircraft carrier Historian's nemecis.... Pt 2
PostPosted: Mon May 20, 2019 6:15 pm  (#2)
I'm not great at photo retouching,
but here's my go.
At trying to make this image look a bit better.
PostPosted: Mon May 20, 2019 7:51 pm  (#3)
Wallace!! What do you mean, you are not good a retouching! Beautiful job! I don't think I need to submit mine now, but here goes.
PostPosted: Mon May 20, 2019 10:09 pm  (#4)
Wallace, how did you get the ship brightened up no nicely? I had a lot of trouble with that and still not as clear, bright, and clean as yours.
PostPosted: Mon May 20, 2019 11:34 pm  (#5)
I generally don't remember my steps,
but I can recall this.
I put a copy of the image on top,
and masked out everything except for the ship.
Then I played around with curves to make it brighter.
Than lowering it's opacity and played with layer modes until it looked a bit brighter.
I also used my sharpening technique,
on a New From Viable layer.
Easy Image Enhancement
Sorry Pat625,
that I don't remember more.
:oops:
PostPosted: Tue May 21, 2019 4:39 am  (#6)
I only worked on the sky
opened image
duplicated layer
scaled the top layer down to 10 x 7 pixels
scaled the top layer back up to 1024 x 704 pixels, this gives a clean sky and blurry carrier
scaled top layer again to 1024 x 804 pixels, then dragged the top layer down till top edges of both layers match, this is done to place the dark blurred carrier lower in the image so as not to be visible when combing layers
roughened the sky, as rendered in this way it has a too smooth plastic look to it
used a mask in the usual way to combine what is wanted from each layer
steve
PostPosted: Tue May 21, 2019 6:45 am  (#7)
I like what Steve did. It retains the original look, the shadow of the ship turns out bit strange, looking like mud if you edit the sea too much.
But you all did good job.
