It is currently Sat Nov 07, 2026 5:31 pm
 Post subject: Upholstery Repair.
PostPosted: Sat Jul 24, 2021 8:17 pm  (#1)
GIMP Version: 2.10.18
Operating System: Linux
OS Version: Linux Mint 20.1 x64
I recently had a shoot on a boat with some of the seating material giving way; I'm looking for suggestions as to how to repair the tears in the GIMP. The more convincing the better of course, but the work really only has to be less distracting than the half-naked models. How should I tackle this? Any assistance is appreciated, thanks.
 Post subject: Re: Upholstery Repair.
PostPosted: Sun Jul 25, 2021 2:00 am  (#2)
This is quite easy, and the slight overcast will help you as well as you won't have real problem with the light, it's typically a... patch work :hehe
On the first one I would patch the part i put in black rectangle (or the and/one at the bottom right) in place of the broken part (select/copy/paste new layer, rotate, move, duplicate for the second part, mask, and may be some clone tool and curves to fine tune)
On the second one I would search on the different pics you have, a corner to patch which can fit better than the actual one to patch it as well
IMHO, next time, just bring some towels ;)
Patrice
PostPosted: Sun Jul 25, 2021 5:13 am  (#3)
Try Heal selection in Filters. You will need to d/load the plugin if it is not there.
Image Image
PostPosted: Sun Jul 25, 2021 5:20 am  (#4)
Oh yea! I forgot his one :bigthup
Patrice
PostPosted: Sun Jul 25, 2021 6:15 am  (#5)
If you want Gimp to fix your tears you may be in for a let down :( . However we can do something about the photo. I have done one and am working on the second, not with a lot of success though. Maybe someone will get in before me. By using a bit of cloning and healing. Tried with the deformation tools but am not proficient enough with them.
My try on ex1
PostPosted: Sun Jul 25, 2021 6:21 am  (#6)
[ Image ] [ Image ]
you also have the heal brush tool in 'tools' Comes with Gimp
PostPosted: Sun Jul 25, 2021 7:28 am  (#7)
[ Image ] [ Image ]
WoW! Thank you!
PostPosted: Sun Jul 25, 2021 7:29 am  (#8)
My try on ex1
Outstanding. Thanks to you all, this gives me hope.
PostPosted: Sun Jul 25, 2021 8:58 am  (#9)
sallyanne wrote:
[ Image ] [ Image ]
63 is speaking about another "beast", which takes only few seconds
make a selection of the defect then > Filters > Enhance > Heal selection
It will replace the selection automatically for you with surrounding pixels in a matter of seconds
Select defect
3 seconds later... voila!
Patrice
PostPosted: Sun Jul 25, 2021 10:37 am  (#10)
Well, I had a hell of a time getting the Resynthesizer plugin installed and running, but...oh yeah, it was worth the hassle. Thanks again to everybody that responded.
PostPosted: Mon Jul 26, 2021 1:38 am  (#11)
I understand. Had it before myself. Just pointing out there is another one. :)
PostPosted: Mon Jul 26, 2021 6:11 am  (#12)
Oh sorry, my bad, I did misunderstood :oops:
Patrice
