It is currently Thu Nov 12, 2026 8:39 am
 Post subject: Seeking method restoring colour of old photo
PostPosted: Fri Sep 29, 2023 5:54 pm  (#1)
Hi all,
I have old colour photos in yellowed color but without scratch. My PC is connected to a 4K display and running Ubuntu 22.04 desktop
Please advise;
1) How to remeve the yellowed color.
2) How to restore their original color
3) How to increase their sharpness
Thanks in advance
Regards
sample photo attached
 Post subject: Re: Seeking method restoring colour of old photo
PostPosted: Fri Sep 29, 2023 8:48 pm  (#2)
I think you can skip out on restoring color. Although there are still some colors information, it'll be very hard for you to restore them.
PostPosted: Fri Sep 29, 2023 10:42 pm  (#3)
Hi,
Thanks for your advice.
Before posting I have performed following tests:
A. On GIMP
1) Colors -> Curve
adjusting red/green/blue
2) Colors -> Hue-Saturation
Brightness-Contrast
3) Colors -> Curve
etc.
The yellowish color can be removed, some colors, such as grass, trees, etc can be restored. The photos are NOT very sharp after restoration.
B. AI Photo Editor online FREE
The result is worser than editing the photos on GIMP.
According to my recollection . I scanned the yellowish photos on Epson scanner and posted them on my website. Not all photos are so bad, only some of them.
I still have those yellowish photos and their negatives packed and stored on shelves. But it won't be easy for me to find them.
I have full knowledge scanning both photos and their negatives on mobile phone converting them to digital images. I have done them before. The mobile phone was nevigated via PC (Remote Desktop connection). I still have the fixture available.
But I have more than a thousand of photos and their negatives. It would take a long time to finish. Particularly the negatives, there is no marking on them indicating where they were captured.
Those photos were captured in the past when I travelled worldwide.
Suggestion would be appreciated.
Regards
PostPosted: Sat Sep 30, 2023 1:36 am  (#4)
A quick try at the sample image using the plug-in - col-cast-reduction.py - resulted in this image.
Applying a contrast mask to the result produced the following image, still not very good, but perhaps a starting point for further enhancement.
PostPosted: Sat Sep 30, 2023 2:05 am  (#5)
The attachment london_11_river_thames30_1.png is no longer available
The attachment london_11_river_thames30_2.png is no longer available
upload photo was restored by me before starting my posting but no sharp
PostPosted: Sat Sep 30, 2023 2:16 am  (#6)
Hi,
Continued
Upload photo was captured at about the same in London. You can see the restored result made by me. Although the restored photo is not sharp enough but its quality is acceptable. It is a colour photo
Regards
PostPosted: Sat Sep 30, 2023 2:36 am  (#7)
satimis, I'm not an expert but I did my try.
PostPosted: Sat Sep 30, 2023 2:53 am  (#8)
my try at editing with colour???
2nd one
PostPosted: Sat Sep 30, 2023 2:55 am  (#9)
Hi Issabella.
Well done.
Could you please advise the steps performed ? Thanks
Regards
PostPosted: Sat Sep 30, 2023 2:57 am  (#10)
Better. Can the photo be sharper?
Regards
PostPosted: Sat Sep 30, 2023 3:07 am  (#11)
Regards
Doubt it very much. A lot of the definition in the foreground seems to be gone.
PostPosted: Sat Sep 30, 2023 4:21 am  (#12)
Hi Issabella.
Well done.
Regards
I started since your well done outcome. So I started from your image. Then I tried to remove the blur, Filters - Enhance - Sharpen Unsharp Mask.
After that Colors - Exposure and added much Black Level. Finally Colors - Hue-Saturation and added Saturation.
You did a nice job :coolthup
PostPosted: Sat Sep 30, 2023 5:39 am  (#13)
Hi Issabella.
Well done.
Regards
Thanks for your steps
On Export the photo what level should I select? The default is [9]
Thanks
PostPosted: Sat Sep 30, 2023 7:49 am  (#14)
Colors - Exposure
I don't remeber exactly I applied but about 30
And satutation, so the colours get a better look. :)
PostPosted: Sat Sep 30, 2023 8:04 am  (#15)
You could apply Advanced Tone Mapping after that. The background is better.
Filters - Enhance _ Advanced Tone Mapping
PostPosted: Sat Sep 30, 2023 8:06 am  (#16)
Colors - Exposure
Thanks
PostPosted: Sat Sep 30, 2023 8:21 am  (#17)
Sorry.
Filters -> Enhance -> no "Advanced Tone Mapping" here
PostPosted: Sat Sep 30, 2023 8:31 am  (#18)
I hope you can get it. It is a Script. Set it in Script Folder
After that start Gimp
advancedtonemapping.zip [1.98 KiB]
Downloaded 307 times
PostPosted: Sat Sep 30, 2023 8:48 am  (#19)
I think it is here;
http://zarniwhoop.uk/advancedtonemapping.html
Get it here: advancedtonemapping-2.10.scm.
I have this file "advancedtonemapping-2.10.scm" download on Ubuntu 22.04. Where shall I store this file so that it would popup on;
Filters -> Enhance -> Advanced Tone Mapping
Thanks
PostPosted: Sat Sep 30, 2023 8:55 am  (#20)
Yes, that is the one. I sent it in zip above in my previous post :bigthup :)
