It is currently Sat Nov 07, 2026 7:33 pm
 Post subject: batch processing photo, pease please any help on this im stuck
PostPosted: Thu Sep 04, 2025 4:07 am  (#1)
Hi, can you help me, im trying to batch process some photos, Idea is so I can have lots of photos in one folder and use a programme or something maybe made specifically for me so I can batch process images in folder into a specific folder called in filters the extended filter contour , its called super pixel. Can anyone help me with this please, Im lost. I see says can copy command to clipboard, jut just dont know how to batch process that command.
Any help advice really appreaciated.
Thanks
Charles
 Post subject: Re: batch processing photo, pease please any help on this im stuck
PostPosted: Thu Sep 04, 2025 5:34 am  (#2)
By the way, Welcome to Gimp Chat!
PostPosted: Thu Sep 04, 2025 6:15 pm  (#3)
The issue with Gimp is that 'batch scripts' are run from a command line and Gimp was never developed as a command line tool.
G'MIC and GEGL both have a command line capability.
How To Run A GMIC Filter On Hundreds Or Thousands Of Layers
This is similar to the Gimp G'MIC-Qt 'apply to all layers' except this command will usually stop at a limited number of layers (frames).
We had a lot of fun doing animations back them :)
PostPosted: Fri Sep 05, 2025 1:31 am  (#4)
Welcome to Gimp Chat cpxa. :)
What version of Gimp are you using? Batcher is a great program for batch processing images.
If you are using Gimp-3.
viewtopic.php?f=11&t=21588
