It is currently Sat Sep 26, 2026 9:53 pm
 Post subject: Scanner Image cleanup help
PostPosted: Sun Nov 18, 2012 5:48 pm  (#1)
I found this old (1984) Pentax PC35 AF-M SE in a drawer today. I couldn't find the manual so I found a poorly scanned copy on the net, while good enough, I want to experiment with cleaning it up. Any tips or scripts that would help? I wouldn't bother asking but there are 32 pages. This cameras is very well made, in perfect condition, I figured why not see how it goes.
Here's a sample of what the manual looks like.
 Post subject: Re: Scanner Image cleanup help
PostPosted: Sun Nov 18, 2012 7:25 pm  (#2)
here's a link to another pdf
pc35afm
PostPosted: Sun Nov 18, 2012 8:02 pm  (#3)
pc35afm
Thanks for the link but it doesn't work for me. So I went to the web site, did a search and the manual didn't come up either. I checked their WOT Reputation Scorecard and decided to stop. I've already checked a few other sites and all the manuals I've found are the same quality.
So now I'm going to use this PDF as an experiment and clean it up. I was hoping there was someone with experience may have a workflow in place. A nice new manual would be fine but a clean up excercise might be more fun!
PostPosted: Sun Nov 18, 2012 8:21 pm  (#4)
I already have it downloaded if you want it
PostPosted: Sun Nov 18, 2012 10:46 pm  (#5)
You probably know that you can edit pdfs with open office and libre office?
PostPosted: Mon Nov 19, 2012 12:35 am  (#6)
Probably, the best tool for the task would be NuvolaTools
Too bad, although a Python script, it is Linux-specific (has too many linux environment dependencies if I understood correctly) and has to be rewritten(?) to make it work in Windows or Mac.
But maybe, there is a way to install all those dependencies and get it to work on Windows system? I think Ofnuts is one of the few here who is familiar with Python scripting language and could answer this question.
BTW, the script has a great potential, I'm actually surprised it hasn't been done already.
PostPosted: Mon Nov 19, 2012 4:28 am  (#7)
Thanks for the reply, I know you can make and edit PDF's with Open Office, but I don't think you can edit PDF's made by another program. In this case it's totally an image cleanup job. I will use Open Office to make the PDF now that I'm done the cleanup part.
Thanks for the tip, I'll check it out. I'm almost done the manual now, here's a before and after example.
PostPosted: Mon Nov 19, 2012 4:35 am  (#8)
Thank you, I appreciate that!
PostPosted: Mon Nov 19, 2012 8:15 am  (#9)
:bigthup Good job on the cleaaning up. :bigthup
