It is currently Wed Aug 05, 2026 9:27 pm
 Post subject: BW recolored
PostPosted: Sun Jan 06, 2013 11:22 pm  (#1)
Before:
And after I colored it:
 Post subject: Re: BW recolored
PostPosted: Sun Jan 06, 2013 11:25 pm  (#2)
Nice one, ek22!
PostPosted: Mon Jan 07, 2013 4:15 am  (#3)
Well done!.
Paintihg with brush each color or colorized it using selections?.
There is another way: using G'mic B&W recolorize, but it's difficult to me.
PostPosted: Wed Jan 09, 2013 12:00 am  (#4)
excellent result!
PostPosted: Wed Jan 09, 2013 12:50 am  (#5)
jamac4k wrote:
Well done!.
No I made a layer for each color and colorized it in the hue I wanted, then used layer masks to make the color fit the area it should apply to. There's about 15 layers of colors in that.
I could have sworn someone here did a tut on it a little while back but I couldn't find it again. That's what got me thinking about it.
PostPosted: Wed Jan 09, 2013 8:45 am  (#6)
ek22: whew, fifteen layers of colour sounds like a lot of work! but the result is very good, i think.
PostPosted: Wed Jan 09, 2013 10:58 am  (#7)
You've done that really well EK.
PostPosted: Thu Jan 10, 2013 11:15 am  (#8)
Really excellent job, I'm intrigued how you done the hair as it appears each individual strand from the scalp has been coloured.
PostPosted: Mon Jan 14, 2013 7:14 am  (#9)
Uh well, basically, it's a super-soft paintbrush, in places I used the airbrush tool too. On a masked colorized layer. Like I make a BW layer of the image, then I duplicate it and colorize it in the shade and saturation I want. And then I paint the color in with the help of a layer mask. The key for the hair line was a real subtle touch with a very soft tool.
I was sure someone here did a tutorial on it already, but if no one has, I can maybe see about putting one down when I get my replacement comp.
PostPosted: Mon Jan 21, 2013 9:26 pm  (#10)
Using Gmic recolorize
bbbbbbbbbbbImage
PostPosted: Mon Jan 21, 2013 9:32 pm  (#11)
Great job, Akros :bigthup
It's an amazing filter!
PostPosted: Mon Jan 21, 2013 10:36 pm  (#12)
Yeah, I'm impressed with how well it works. Though there are a couple of places where it skips over the details. Like her ring for example. But then I'm a bit of a stickler for perfection.
PostPosted: Sat Jun 14, 2014 6:24 pm  (#13)
Using layers
The background I used another image
It has some flaws in the contours, but as I was just focused in coloring, had lazy to retouch it.
bbbbbbbbbbbImage
PostPosted: Sat Jun 14, 2014 7:26 pm  (#14)
EK22 and Akros , really nice work.
EK22 , I think you are referring to the recent discussion on Luminosity masks. In particular there was as reference by Odin to an article by Pat David which was very good. There was also a discussion in MeetTheGimp for doing a duotone which uses soft (not thresholded) masks for colorising a B/W.
PostPosted: Sat Jun 14, 2014 8:26 pm  (#15)
nice guys.
I did this one a while back.
For the skintone i used colors -> map -> sample colorize and selected a patch of skin from another colored photo that had dark and light and mid tones of color skin.Image
i didnt' spend too much time on the hair line you can see where it gets the dark of color skintone instead of hair. I purely wanted to play around with the colors->map->sample colorize.
TinT
PostPosted: Sat Jun 14, 2014 8:48 pm  (#16)
I did this for a memorial poster, so I tried to make the colors faint but realistic, like an older faded picture.
oops, what?
Tries again…Image
PostPosted: Sun Jun 15, 2014 12:23 am  (#17)
Where is recolorize found in GMIC? i can't seem to find it
TinT
PostPosted: Sun Jun 15, 2014 4:59 am  (#18)
It is under BW black and white Image
PostPosted: Sun Jun 15, 2014 1:43 pm  (#19)
trandoductin I had gone through your blog and read your suggestion. Then follow the links you cited.
That was how I ended up coloring the image (#13)
Thanks for the tips! :bigthup
wbool63 this is interesting.
I will now search for this technique with duotone.
Thanks for the comment and for the tip!
bbbbbbbbbbbImage
PostPosted: Sun Jun 15, 2014 1:49 pm  (#20)
how did you know i had a blog? have you been stalking me? hehe
So you did use other reference images to use as color then?
TinT
