It is currently Wed Sep 30, 2026 10:46 am
 Post subject: [SOLVED] removing red eye and fixing the white eye.
PostPosted: Tue Nov 30, 2010 6:09 am  (#1)
Is anyone up for the challenge of fixing this twins eyes. I did it but it isn't perfect, using the red eye tool on one eye and the color picker on the other.
 Post subject: Re: removing red eye and fixing the white eye.
PostPosted: Tue Nov 30, 2010 9:19 am  (#2)
First I fixed the red eye, copied the selection and pasted it into a new layer.
Then I positioned the copy of it over the white eye.
Also I worked with hue & saturation to get rid of the extra red reflection on the eyelid above the red eye and to the pinkness of the white of the eye. In H&S I selected red and desaturated a little. On the eye white I also lightened just a little.
PostPosted: Tue Nov 30, 2010 9:31 am  (#3)
O that is a great job "O", thanx a lot.....
 Post subject: Re: [SOLVED] removing red eye and fixing the white eye.
PostPosted: Tue Nov 30, 2010 9:36 am  (#4)
Thank you. It turned out better than I thought it would. That red eye removal filter works great. I think I set the threshold up to about 78 if I remember correctly.
PostPosted: Tue Nov 30, 2010 10:10 am  (#5)
Thank you so much O... I didn't know you could use the red eye on the white eye so I used the color picker and did it that way. perfect job......
PostPosted: Tue Nov 30, 2010 10:14 am  (#6)
:lol I didn't know that either until I tried it. I didn't know how else to fix the white eye.
PostPosted: Wed Dec 01, 2010 11:34 am  (#7)
Those results are great O! =)
PostPosted: Sun Sep 18, 2011 11:04 pm  (#8)
Molly, I hope you get this, I know it's been a while since you posted this thread. I came across this tonight while trying to find tips on fixing the white eye in a pic of my twin daughters. Searching a little more, I discovered that a white eye like this is NOT normal and is generally a sign of a type of optical cancer called retinoblastoma and is very dangerous. It may not be cancer; if the light happens to hit the optical disc in the eye just right, it can also cause a white reflection, but only a medical exam can tell for sure. Please, if you haven't called your doctor yet, please do so imediately. I will be calling ours first thing in the morning. I pray the best for you.
