It is currently Tue Oct 06, 2026 12:41 am
 Post subject: Postcard Resolution
PostPosted: Mon Nov 25, 2013 2:42 pm  (#1)
I am designing holiday postcards for my husbands business, Before I start I need to know what resolution setting I should use. I am thinking around 300 dpi but I want to make sure.
 Post subject: Re: Postcard Resolution
PostPosted: Mon Nov 25, 2013 2:48 pm  (#2)
300 DPI sounds about right. You should check the resolution of the printer you will be using to print the cards and use that setting.
