It is currently Sun Oct 04, 2026 6:58 pm
 Post subject: Pixo
PostPosted: Tue Jan 18, 2011 5:14 am  (#1)
download of the day
Paint on your effects! - pretty cool :)
http://simply-signage.com/blog/?cat=15
I downloaded it and it allows you to use PS filters and a whole bunch of other filters pre installed to create some nice results.This is pretty nice for free.
 Post subject: Re: Pixo
PostPosted: Tue Jan 18, 2011 5:33 am  (#2)
I tried it, the registration wouldn't work. Bummer.
PostPosted: Tue Jan 18, 2011 7:57 am  (#3)
I downloaded it and registered it and got confirmation etc. BUT I can't type in my password cuz it is blocked, it wants you to buy or use the trial 15 day version. ??????????
PostPosted: Tue Jan 18, 2011 10:02 am  (#4)
Did you choose multiuser folks? (not single user)
It worked fine for me.
I opened the zip - inside was a
text Readme file with instructions for entering the user and reg key
I ran the installer and it unzipped a setup file.
I ran the setup and clicked on multiuser
Added my key and user name and it registered. =)
PostPosted: Tue Jan 18, 2011 10:09 am  (#5)
I clicked single user, maybe that is the prob. thanx I will go back and try it. If I don't post back, it didn't work.
PostPosted: Tue Jan 18, 2011 10:22 am  (#6)
Ok, here is what I did, for a registration name, I typed in Giveawayoftheday.....
For a code, I typed in the long number starting withDFF75FB1CEB8275641821B-----------
You can't copy and paste it in, it wouldn't let me. I had to put it manually......
It worked. woo hoo :jumpclap :clap :tyspin :coolthup :wh
PostPosted: Tue Jan 18, 2011 11:02 am  (#7)
Glad to hear it Molly.
I just went through all the pre-installed filters...wow!
Plus if you open any image and click the filter window until you see a window with a outlet plug in it.
Click that preset window and a list of presets will open.
Click a preset in the list and click apply - the preset will load
Soon a window will open with an ok on it click it and your ready to paint on the effect!
What i like about this program, is that you can apply the effect anywhere without making a selection. =)
Click the little plug icon on the top/right and you can load any PS filter into it.
Just click the folder underneath the window and browse to one of your 8bf's. - nice!
PostPosted: Tue Jan 18, 2011 12:15 pm  (#8)
I haven't been in the photoshop part of it yet but I have tried a lot of the filters going down the line. I didn't see the red eye one yet. It keeps locking up on me and I lose everything. I think I will reboot to see what happens. Yes, it is very interesting so far. thanks Rod.
PostPosted: Tue Jan 18, 2011 2:07 pm  (#9)
It's ok I guess. It applies the selected filter to a copy of the image in memory, and then when you paint the image, it basically substitutes one for the other. It's like duplicating a layer, applying a filter to the bottom layer and then using the eraser tool on the top layer. It's really not much more than that. Glad it was free, because I'd be disappointed to buy it.
My Sigs = My Photos
