It is currently Mon Oct 05, 2026 12:08 pm
 Post subject: Inkscape 1.0 new features overview
PostPosted: Fri Aug 29, 2014 4:02 pm  (#1)
new coming features overview - Inkscape 0.91(pre-1)
You can download and test 64-bit Inkscape 0.91 (pre-1.0) here http://sourceforge.net/projects/inkscap ... /0.91pre1/
 Post subject: Re: Inkscape 1.0 new features overview
PostPosted: Fri Aug 29, 2014 4:17 pm  (#2)
Thanks K1TesseraEna. I am checking out the 64 bit version now.
PostPosted: Fri Aug 29, 2014 6:20 pm  (#3)
Funny you mention this, I just download portable inkscape. ;)
PostPosted: Sat Aug 30, 2014 8:10 am  (#4)
I love the new drag drop symbol widget they added. I can't wait to add my own.
Measure tool works great also.
You can actually create a symbol in the document and add it to your symbols. Sort of like Adobes "smart objects".
Pretty nifty! :)
Any document with symbols can serve as a source for a symbol library. Simply copy it to the symbols directory in your configuration directory (typically share/inkscape)
PostPosted: Sat Aug 30, 2014 10:38 am  (#5)
I wonder if you can export a bitmap image with layers like you can with Illustrator. I usually export an Illustrator file with layers as a .psd and open it with gimp and it works pretty good. I don't have Inkscape but that would be the one thing I would look for before getting it.
Or exporting svg with laters that would open up in gimp as path layers would be good too.
PegLeg
PostPosted: Sat Aug 30, 2014 1:20 pm  (#6)
PegLeg
No, Inkscape can't export psd files but it can export each layer as individual svg file which you can open as layers in gimp
@Rod Cool additions! I've been playing with .91 for a couple hours and haven't noticed any major problem so far. :bigthup
