It is currently Sat Oct 03, 2026 7:17 pm
 Post subject: Celtic Knot Generators
PostPosted: Tue Feb 03, 2015 10:16 am  (#1)
Here's a nice little toy:
http://w-shadow.com/blog/2012/05/17/cel ... or-canvas/
IMHO easier to use than Knotter and it's a browser app (HTML5 <canvas>) so platform-independent.
Only had a little play so far:
Still think it should be possible to do this in Gimp.
 Post subject: Re: Celtic Knot Generators
PostPosted: Tue Feb 03, 2015 10:41 am  (#2)
BTW
If you set the Tools to "Open border" and then use "Randomize" the output pattern is in most cases a seamless pattern
eg.
PostPosted: Tue Feb 03, 2015 11:18 am  (#3)
Very nice jontait2, made it into a nice seamless sphere.
Image Image Image
PostPosted: Tue Feb 03, 2015 12:23 pm  (#4)
Thanks for the link but IMHO Knotter is much better. :)
PostPosted: Wed Feb 04, 2015 10:04 am  (#5)
http://gimpchat.com/viewtopic.php?f=11&t=9591#p124894
The knot making software is by far the easiest way though :mrgreen:
PostPosted: Wed Feb 04, 2015 7:25 pm  (#6)
Yeah, when I said "do this in Gimp" I meant in a semi-automated way (rather than using labour-intensive methods like the path-tools). Would have to be a plug-in, GUI-driven like Knotter or the utility I linked to above.
The latter is good for quick doodles and generating interesting (random) seamless patterns which you can then colour-in and manipulate, eg. one with gold and chrome BRL:
Image Tiled: Image Mapped to sphere: Image
..but it does have its obvious limitations:
- does not do "diagonal cuts" in the lattice;
- uses same width and colour throughout;
- only does rounded shapes, not "pointed corners".
PostPosted: Thu Feb 05, 2015 2:04 am  (#7)
An interesting thread so I downloaded Knotter as discussed above and am trying to learn how to produce those clever Celtic knots ... but its also good for other things like Knotter+GIMP+GMIC+BRL ...
... while I go through that Knotter learning process! Thanks for identifying a new toy for me!!
PostPosted: Thu Feb 05, 2015 2:47 am  (#8)
Just glad this topic came up; hadn't installed knotter since ol' Betsy died on me. I like the knot fill feature that knotter has. You can fill an arbitrary selection with knots that is. Did a trace for this one that's knot me. lol
PostPosted: Thu Feb 05, 2015 11:32 am  (#9)
Knotter was one of the first programs i re-installed. On the same subject have you tried Rob and MareroQ's Knotter Switch plug-in? It opens Knotter from GIMP.
KnotterShwithforGimp.zip [821 Bytes]
Downloaded 210 times
Just unzip to your plug-ins folder.
Tools>Tool from beyond GIMP
PostPosted: Thu Feb 05, 2015 11:59 am  (#10)
That's interesting.
Can you give us a screenshot of the interface, or is there already one posted?
PostPosted: Thu Feb 05, 2015 12:08 pm  (#11)
That's interesting.
Wallace the python file opens Knotter (the program) And you can then create a knot , select all the nodes, and edit>copy - Edit>paste into GIMP as a path. Then you can stroke the path with a brush or do what you want with it. Many possibilities. You have to have Knotter for the python filter to work. Also you will need to edit the python file to point to your portable knotter directory executable file.
from gimpfu import *
import shlex
import subprocess
import os, sys
import tempfile
def plugin_main(img, drawable):
  command = "\"C:\\Portables\\knotter-0.9.6\\knotter.exe\""
Here i created letters in Knotter and pasted the path into GIMP and stroked the path with the Christmas lights GIH. :)
Which means it's great for making PhotoFonts. :bigthup
PostPosted: Thu Feb 05, 2015 1:34 pm  (#12)
import shlex
import subprocess
import os, sys
import tempfile
Cool, thanks Rod. :bigthup
PostPosted: Thu Feb 05, 2015 3:45 pm  (#13)
I've not tried the python interface or the built in GIMP interface within Knotter itself Rod. Not the way I like using either program. May be useful for some but again, I follow my own piper if you will. lol
PostPosted: Thu Feb 05, 2015 4:59 pm  (#14)
knotter plus gimp
