It is currently Fri Oct 02, 2026 10:15 pm
 Post subject: Camera 360 application
PostPosted: Sat Aug 22, 2015 12:26 am  (#1)
Hi friends.
I like to recommend the application Camera360.
This application is for iPhone or Android
There are a large number of effects that you can run from the application.
You can run the effect while taking the picture.
It is also possible to run the effect to an image that already exists on the phone.
I am attaching the original picture and the picture with one of the effects.
I really like the app play and enjoy.
Doron.
 Post subject: Re: Camera 360 application
PostPosted: Sat Aug 22, 2015 12:30 am  (#2)
I add a photo with the logo of the application.
PostPosted: Sat Aug 22, 2015 1:23 am  (#3)
Thanks for sharing doronf. :tyspin
