It is currently Sun Oct 04, 2026 9:10 am
 Post subject: Unshake Program Tests
PostPosted: Sun Oct 18, 2015 11:40 am  (#1)
As you know, I posted this photo on another thread, to learn about different de-blurring techniques. I wanted to use the Unshake program exclusively, to try a little testing. What I did, was to take the stock photo, run it through, only changing the time to x2, then running that result through it again, with the same settings. Here are the results. Stock photo:
Test 1:
Test 2:
Test 3:
Test 4:
Test 5:
Test 6:
Test 7:
Test 8:
As you can see, it did clear up a bit each time. It did get slightly darker each time as well. The later results had some slight change, but were basically negligible.
Here's an animation, showing the difference between the stock photo, and the last test. A significant difference:
Here's an animation showing every layer change. Changes are 1 second apart:
Thanks for looking.
 Post subject: Re: Unshake Program Tests
PostPosted: Sun Oct 18, 2015 12:34 pm  (#2)
That's awesome. I don't think the darkening is a problem here, and the whites still stay white, just seems to be a lot more contrast.
PostPosted: Sun Oct 18, 2015 12:47 pm  (#3)
I agree. The darkening is no problem at all. Even if it were, it would be easy to lighten back up.
PostPosted: Sun Oct 18, 2015 1:05 pm  (#4)
Impressive; is it a GIMP plugin? :)
PostPosted: Sun Oct 18, 2015 1:36 pm  (#5)
It's a stand alone, but you can run it through Shellout, if you're smarter than I am, haha.
PostPosted: Sun Oct 18, 2015 1:38 pm  (#6)
Attached is an LAB color corrected copy of your original image. I decomposed to LAB, A/B curves and L Unsharpen mask. It seems to improve the clarity of the base image. Try a go with the LAB layer.
gc-test-2834_22-LAB.xcf.bz2 [3.49 MiB]
Downloaded 166 times
PostPosted: Mon Oct 19, 2015 6:50 am  (#7)
Java file Lyle. :)
You can run it through Shellout with a bat file.
