It is currently Tue Nov 17, 2026 6:33 am
 Post subject: Envelope in Inkscape
PostPosted: Sun Apr 24, 2016 12:04 am  (#1)
Hi There,
Today I was learning how to draw a glucose shaped prism like shape. After creating that I got the look of an incomplete envelope. I tried to complete it and I was successful. (At least I think).
Suggestions and criticism are welcome.
With Best Regards.
 Post subject: Re: Envelope in Inkscape
PostPosted: Sun Apr 24, 2016 12:22 am  (#2)
Rashid wrote:
Hi There,
With Best Regards.
Very nice rendering! :bigthup
It does however look a bit flat.
Perhaps adding drop-shadows to the overlapping folds, would help it to look less flat.
PostPosted: Sun Apr 24, 2016 1:38 am  (#3)
Thanks Mr. Wallace. Drop shadow is such an important aspect in drawing that without them things appear to be far from reality.
I added 'drop shadow' where it was needed. Now it is very much better than my previous attempt.
PostPosted: Sun Apr 24, 2016 3:24 am  (#4)
Rashid wrote:
Thanks Mr. Wallace.
No problem Rashid.
This looked like fun,
so I thought I'd also make an envelope using Gimp.
PostPosted: Sun Apr 24, 2016 4:13 am  (#5)
Excellent. Very neat.
I am not able to refine drop shadow that much in Inkscape as you have done in Gimp. In my previous attempt in Inkscape I used 'pattern along path' option in Inkscape. This time I used a different approach for border and I could not do that.
PostPosted: Sun Apr 24, 2016 4:37 am  (#6)
Thanks Rashid! :bigthup
I enjoyed making the envelope.
The shadows really make it pop.
PostPosted: Mon Apr 25, 2016 2:16 pm  (#7)
Thanks to Gimp Chat member Trandoductin.
This topic had given birth to a new topic.
It's called Design your own Aerogram and you can view it using the link below.
PostPosted: Wed Apr 27, 2016 1:10 am  (#8)
Today I tried to improve the drawing in Inkscape. I applied gradient to stroke and then blurred it.
You may be wondering the reason of such odd size envelope. In my mobile phone screen I have such an envelope icon which is in accordance with with other icons.
I hope you would like it.
PostPosted: Wed Apr 27, 2016 4:13 am  (#9)
Well done Rashid. :jumpclap
